please help guys do any of you guys have step to step installation for koni yellows for 2000 integra
Old Mar 22, 2004 | 05:43 PM
greenteg2k00's Avatar
Default please help guys do any of you guys have step to step installation for koni yellows for 2000 integra
i think i installed mines wrong, the instructions from koni are wrong, please help guys
Old Mar 22, 2004 | 05:45 PM
Default Re: please help guys do any of you guys have step to step installation for koni yellows for 2000 int
go to this link guys and look at my setup i heard they said i installed perch upside down , please help me guys ,look at my setup http://www.honda-acura.net/for...29746
go to bottom of post for the pics
Old Mar 22, 2004 | 06:09 PM
bump it
Old Mar 22, 2004 | 07:09 PM
ingrate's Avatar
25 Year Member
The instructions from koni looked fine to me.
The shaft on the koni shocks are 12mm compared to 10mm for the stock shocks. so for the dust cover, standard procedure is to use a round file or a 12mm drill bit to enlarge the hole. Technically you're supposed to chop it down to 1.5" to 2" in length if your car is lowered a lot to keep it from bottoming out.
Then you tap out the round bracket from the stock shocks that holds the brake line with the little nipple at the bottom and tap it onto the koni shock, with the nipple-looking thing centered in that little dent you see near the bottom of the shock. That dent is there so the bolt that holds the fork to the shock body doesn't rub up against anything.
And if those are your front shocks in the attached pictures, your perch IS upside down. The cupped side should be facing down. Make sure you don't forget to put the washer on the c-clip before putting on the perch. I learned that the hard way
BTW the metal tube with the black rubber bushing at the top should be stuffed inside the other bushing in the top hat also. I don't know if it makes any difference after everything's put together, but that's how i always did it. Oh and your rubber bushings may be facing the wrong direction also.
Modified by ingrate at 8:23 PM 3/22/2004
Old Mar 22, 2004 | 07:27 PM
are you sure the perch is upside down how come, when koni ship it out it came out the box the perch was like that out of the box, please help me you got detailed instructions
Old Mar 22, 2004 | 07:33 PM
brickonwheels's Avatar
i know team-integra.net has an install
Old Mar 22, 2004 | 07:36 PM
ingrate's Avatar
25 Year Member
The perch was already on the shocks when koni shipped it to you?? All the parts should've been in separate plastic bags if you purchased them brand new.
If you need a better idea of how it's supposed to go on, look at the perch on your stock shocks.
For the fronts it's supposed to look like:
instead of
Old Mar 22, 2004 | 07:38 PM
yes it was shipped brand new i have the new neuspeed koni sp3 koni yellow 5 way adjustment and it came brand new from neuspeed with the perches already on the shocks
Old Mar 22, 2004 | 08:21 PM
litlekikr's Avatar
washer over the c clip? uhh, what washer would this be and what happens if it's not installed? mine are installed EXACTLY like the pictures and directions but theres no washer betweeen the clip and the perch.
Old Mar 22, 2004 | 08:36 PM
i dont know what washer myself
Old Mar 22, 2004 | 08:45 PM
what washer are you talking about the new one or stock washer
Old Mar 22, 2004 | 09:59 PM
ingrate's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litlekikr &raquo;</TD></TR><TR><TD CLASS="quote">washer over the c clip? uhh, what washer would this be and what happens if it's not installed? mine are installed EXACTLY like the pictures and directions but theres no washer betweeen the clip and the perch.</TD></TR></TABLE>
If you look at the directions more closely, you will see there is supposed to be a washer over the c-clip to help spread the load. I ran w/o them for a while and part of the c-clip collapsed, but luckily it was still supporting the car. Koni shipped me new c-clips and washers and stuff for free
Old Mar 22, 2004 | 10:22 PM
the c clip is white right so i install the washer on top of it, is that washer y our talking about black metal ring whats the shape of it please help
Old Mar 28, 2004 | 11:18 AM
litlekikr's Avatar
well crap, i went through all my koni boxes and tried to find the washers your talking about but nothing is big enough to actually fit over the shock body. Maybe i need to call them, thanx for possibly saving me some problems though
jv88_dc2
Suspension & Brakes
Apr 12, 2011 12:17 PM
freeagent32
Honda S2000
Apr 12, 2006 08:54 AM
BD7581
Jul 19, 2002 08:53 PM
Krakhor9
14
Jun 10, 2002 07:30 PM
deviant94ex
15
Apr 2, 2002 03:16 PM
