TIMING ISSUES....bad dizzy?
Old Mar 22, 2004 | 03:55 PM
WCI's Avatar
WCI
Default TIMING ISSUES....bad dizzy?
ok I am trying to time a friends 91 teg and when I jump the harness and throw a timing light on it I can't get it on time. Even if I put the distributer all the way advanced I can't get the red mark on with the mark on the cover. I took the distributer apart and there was a tag on it that said it was remanufactured. Just wondering if you guys think it is a bogus one?
Old Mar 22, 2004 | 06:17 PM
Oh Crap's Avatar
Default Re: TIMING ISSUES....bad dizzy? (WCI)
That could be a possibility. I know hondas sometimes have a problem with mechanical advance sticking. To check that, hold the end of the dizzy shaft, and d turn the rotor to one side.. it should have slight play and return to it's normal position (spring back action).
If that's okay, maybe someone put your timing belt off a tooth.
Old Mar 22, 2004 | 09:27 PM
WCI's Avatar
WCI
Default Re: TIMING ISSUES....bad dizzy? (Oh Crap)
Thanks will check
Old Mar 23, 2004 | 11:54 AM
WCI's Avatar
WCI
checked cam timing and it appeared to be on. Timing marks didn't line strait up with strait edge but they didn't look off a tooth. Will check the electronic advance. I am thinking it is the distributer. The car really bogs down untill about 3,000 then feels normal.
Old Mar 23, 2004 | 12:10 PM
mmuller's Avatar
Mad Scientist
get cam timming right and try again, but it sounds like the dizzy.
mmm.Mechanical advance......your dizzy dont have that...
Old Mar 23, 2004 | 12:28 PM
MightyMouseTech's Avatar
It REALLY sounds like the belt is off a tooth. There is no mechanical or vacuum advance on that dizzy.
Old Mar 23, 2004 | 11:45 PM
leadfoot78's Avatar
I have seen that before! It was the cap and rotor. We retarded the dizzy all the way back but the timing gun still said that it was advanced way over 18deg. Once we replaced the cap and rotor all was good again. I would get a new cap and rotor before u buy a whole distributor.
Old Mar 24, 2004 | 09:36 AM
WCI's Avatar
WCI
Default Re: TIMING ISSUES....bad dizzy? (leadfoot78)
Right on thanks, I will try that.
95BoostedEJ1
Dec 13, 2010 09:09 AM
black0hatch
11
Apr 9, 2008 06:54 PM
northemt88
Mar 15, 2008 12:57 AM
Hybridize
Oct 31, 2003 11:31 AM
