what head gasket would fit me best?
Old Mar 21, 2004 | 11:24 PM
GReddy SI's Avatar
Default what head gasket would fit me best?
i have a b16a2 us
t3/t4turbo drag 3 kit
inlinepro manifold
pwr fmic
450cc dsm injectors
hondata s200b
i am planning to run somewhere around 15psi
on stock block and head. just with a good head gasket
what should i go for? Cometic? inlinepro, etc etc.?
Old Mar 21, 2004 | 11:50 PM
chameleon's Avatar
Default Re: what head gasket would fit me best? (GReddy SI)
u can try a cometic 2/3 layer headgasket and ARP headbolts. should work out fine.
Robzible's Avatar
honestly if i were u i wouldnt run an aftermarket headgasket , i have heard bad things about the thick gaskets , somethin to do with how much it seperates the valves from the pistons?? anyway just keep the stock headgasket and run less boost , the compression will make up for some of the power , run around 8-9 with stock gasket
Old Mar 22, 2004 | 12:01 AM
GReddy SI's Avatar
Default Re: what head gasket would fit me best? (chameleon)
if i get any type of aftermarket head gasket do i have to upgrade my head bolts?
Old Mar 22, 2004 | 12:02 AM
Robzible's Avatar
umm i honestly do not know about that , but it seems like the headbolts could possibly end up being too short , is this the path your on?
Old Mar 22, 2004 | 12:13 AM
Adi Radoncic's Avatar
On Fire!
You do not have to upgrade the bolts, stockers will work fine.
Old Mar 22, 2004 | 01:03 AM
Rusty Shackleferd's Avatar
my old set up was similar to yours, I used the following
OEM head gasket w/permitex hylomar spray pt#81998
block guard
head studs @65
50% c12
I boosted 20 using that so you should be fine at 15 if tuned properly.
Old Mar 22, 2004 | 02:34 AM
ATS*Mark's Avatar
OG triple OG
Default Re: what head gasket would fit me best? (10secb16)
damn thats hardcore.
you might as well upgrade to some arp's while your at it , dont want that head lifting under boost . and im using the .43 cometic mls headgasket with no problems whats so ever
Old Mar 22, 2004 | 07:07 AM
92HB_HB's Avatar
Default Re: what head gasket would fit me best? (Hella_JDM)
which gasket would you suggest for a 83 mm bore gsr built and sleeved??
Old Mar 22, 2004 | 10:45 AM
GReddy SI's Avatar
Default Re: what head gasket would fit me best? (92HB_HB)
bump
Old Mar 22, 2004 | 10:54 AM
porsche997dc2's Avatar
I have used stock 0.029 oem and 83mm 0.054 MLS cometic. I like them both. For stock turbo motor, I like to lower compression a little. I would use 0.043 or 0.054 MLS cometic.
Old Mar 22, 2004 | 10:56 AM
b18bturbo's Avatar
Default Re: what head gasket would fit me best? (porsche997)
i would use a cometic .043 for little lower compression but mostly the GE 83mm works great as well with stock thickness. I only use cometic if the deck heigh has been fucked wiht
Old Mar 22, 2004 | 11:59 AM
GReddy SI's Avatar
how much would the cometic h.g 0.043 run $$?
hamizle
Dec 1, 2009 04:55 PM
rags00prelude22
Sep 10, 2008 08:26 AM
turbogreencivic
Sep 7, 2007 05:19 PM
nebulight
Aug 13, 2006 10:00 AM
