TPS sensor wiring...
Can anyone tell me which wire corrisponds to what function?
I'm wiring up my harness to my BBk mustang TB, and need to know what wire is which.
Thanks!
Bryson
Thanks!
Bryson
Well is that the order they appear in on the connector?
If so Id say Green is Voltage reference, Yellow is signal return, and red is your power wire.
Green and yellow could be switched around this is totally a hunch but thats just what Im thinking from what I remember on most 3 wire sensors from good ol tech school.
this is as far as which wire goes where in the connecter on average.
personally i am not sure of there funtion but if you have your old tb use a multi meter to check the resistence between the pins 1-2 2-3 1-3 write them down do the same thing to your new one and hook them up to wich ever is the closest should be wortha try
The Green one is a ground
The yellow one is constant 5V
The red one fluctuates between 0 and 5V depending on how open or closed the throttle is
http://www.integra.orcon.net.nz/tps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Xsi »</TD></TR><TR><TD CLASS="quote">The Green one is a ground
http://www.integra.orcon.net.nz/tps</TD></TR></TABLE>
Thank you very much sir!
Xemu
16
Nov 1, 2006 04:30 PM
T25 civic
Oct 6, 2002 02:11 PM
