tech ???????? bout my headunit
Old Jan 29, 2003 | 03:53 PM
MonkeyMagic's Avatar
Default tech ???????? bout my headunit
i wuz playin around with a set of 10s the other day, and my headunit died.... so i replaced it and the new one doesn't work... i think i checked all the right fuses but i dunno. when wiring the headunit up the red wire goes 2 red and yellow and orange go 2 yellow... or so the instructions say, but when i wire it up like this (orig config b4 it died) it doesn't work, but when i connect red to the yellow and orange and the yellow to the red, it works!... but i have no memory (so no clock, station presets, etc) anybody have any ideas??
Old Jan 29, 2003 | 04:12 PM
jdmotorsports's Avatar
Default Re: tech ???????? bout my headunit (hondadazed)
ok...first off. what does your orange wire from the radio do? its different from radio to radio so i cant say with out knowing what brand you have. if its illumination, then dont connect it. now with that out the way, the red wire is your key on and your yellow wire is your constant/memory lead. hook it up normal and leave that orange wire out. see if that helps.
Old Jan 29, 2003 | 06:00 PM
t0p_sh0tta's Avatar
Default Re: tech ???????? bout my headunit (jdmotorsports)
I think that the orange wire is usually, illumination.
On your wiring harness is there a larger yellow wire and a smaller yellow wire?
Old Jan 29, 2003 | 06:02 PM
TurboBumblBee's Avatar
from the way your described it. you more than likey blew the fuse under the hood.. its the BACKUP fuse.. check it and get back to us.. good luck
civicorprelude6
Audio / Security / Video
Jun 5, 2010 09:29 PM
tyrone2982
Jan 6, 2006 08:07 PM
*Boostwerks*
11
Feb 24, 2005 10:45 AM
red1997civic
Dec 25, 2003 12:50 PM
blackhatchy
Sep 27, 2003 07:43 AM
