SOHC engine with a Cam Gear and using a stock cam --> Benefical or Not?
Old Oct 21, 2001 | 07:20 PM
azn_outlaw's Avatar
New User
Default SOHC engine with a Cam Gear and using a stock cam --> Benefical or Not?
I aksed about cam gears before...
If I used the stock cam on my SOHC engine with aftermarket cam gear
Do i get any gains or there is not point to it all
I am wonderin know is this a good modification to do?
Old Oct 21, 2001 | 07:55 PM
BlackDeuceCoupe's Avatar
HT White Ops
Default Re: SOHC engine with a Cam Gear and using a stock cam --> Benefical or Not? (azn_outlaw)
If you're lucky it'll give you an extra 1-3 HP on the top-end or bottom-end, depending on which way you adjust it, but you can't have it both ways. Actually, it just takes power off one end of the powerband and puts it on the other.
Mostly, they look pretty. Most guys leave the top cover off for [ahem] easy adjusting [wink, wink]. 99% of adjustable cam gears never leave the "0" mark. That should tell you something.
Buy it for looks, not power...
Old Oct 21, 2001 | 09:37 PM
Halive's Avatar
New User
Just checking but they are more benificial(sp?) for dohc engines right?
Old Oct 22, 2001 | 06:58 AM
VTC_CiViC's Avatar
Default Re: SOHC engine with a Cam Gear and using a stock cam --> Benefical or Not? (Halive)
Far more beneficial. On DOHC engines, the ability to seperatley tune the intake and exahust valve timing is what provides the gains you're looking for. For a SOHC, the changes are simply bumping up or reducing the power band (better top end or better low end), but of course since the intake or exahust valves cannot be tuned without disturbing the other, hp gains are typically very small by altering the static position of the cam gear.
Old Oct 22, 2001 | 07:56 AM
itrhybrid's Avatar
If you ever go with an aftermarket cam it will benefit more. Also if you ever change the head gasket thickness you'll need one. say if you wanted to go with a thicker gasket for boost or thinner to raise compression.
James
Old Oct 27, 2001 | 02:19 PM
HT White Ops
Yes, but they are harder to setup correctly. Really, the only way to properly setup DOHC gears is on a dyno.
fryman
16
Oct 26, 2009 11:04 AM
devine wind
10
Dec 19, 2003 12:56 PM
Rocket
Nov 23, 2003 03:16 PM
binkster
Feb 7, 2003 02:59 PM
94civicx
Dec 16, 2001 10:18 AM
