anyones EG-GSR swap, hitting your hood?
do you have the torque mounts in? My lsvtec did that, I don't remember if I had those mounts in at the time though. It hit on the bottom left of my valve cover. I just hit the bottom of my hood with a hammer a little till i got those lower mounts in
i am using 4 out of the 5 mounts, that includes the AC bracket mount. i also have the silvers racing torqe dampner as well that mounts on the drivers side upper mount and hooks to the strut tower. my tranny and AC mount are filled with window weld polyeurethane, so they are real stiff, but when i re painted my car, i didnt use an OEM hood, so the webbing on the underside might be a little thicker.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge »</TD></TR><TR><TD CLASS="quote">i am using 4 out of the 5 mounts, that includes the AC bracket mount. i also have the silvers racing torqe dampner as well that mounts on the drivers side upper mount and hooks to the strut tower. my tranny and AC mount are filled with window weld polyeurethane, so they are real stiff, but when i re painted my car, i didnt use an OEM hood, so the webbing on the underside might be a little thicker.</TD></TR></TABLE>
use all 5
what, are you not using the rear T mount? thats what controls forward and backward rotation of the engine.
use all 5
the only mount im not using is the tranny TORQUE mount.... i am even using A SILVERS TORQUE DAMPNER. it does the same **** on my friends EG b18c. i was just wondering how many have had this problem, or if it were just our cars
on my old coupe w/ a b18c1 it hit the hood a little on the top valve cover where the ground bolt was.. wasnt that bad, i dont think i have the tourqe mounts in there either.. but it doesnt hit on my new car
category5 SI
14
Oct 8, 2014 11:24 AM
Trung Nguyen
18
Jun 15, 2010 02:29 PM
