Idle Problems
Alright i have searched on this topic.since i put my intake and exhaust on my 94 LX,Now my car is idling around 100 RPM,what should it be at?it is kinda stupid question.but i need some help on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic4doors »</TD></TR><TR><TD CLASS="quote">Alright i have searched on this topic.since i put my intake and exhaust on my 94 LX,Now my car is idling around 100 RPM,what should it be at?it is kinda stupid question.but i need some help on it.</TD></TR></TABLE>
I have a similar problem with low idle and i think we're having the same issue here. I don't think putting on the intake or exhaust is doing it, i've had both on over 100k and this is a new problem say 2-3 months ago.
Well i put my intake on right after i bought mine and it had 72,000 on it and ever since then it hasnt idled right,but if any one could help us would be nice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Either that ^ or just adjust your idle higher and no prob. </TD></TR></TABLE>
i have the same problem, and adjusting the idle does not work.
Are you sure that it's Idling at 100rpms? b/c the very first line on the tach is 0rpms then the thinner line between 0 and 1000rpms is 500rpms. If you're mistaken and its idling around 500rpms, its not that bad....try reseting the ecu and see if that helps.
Just disconnect the battery for about 10min. then reconnect it and start the car and let it idle til its at normal operating temp.
Mike
Mike
Yea i tried that and it works for a couple of days and then it goes back to what it is doing.but at night when the air is cooler it will idle around 800 to 900 where it is normal.but it is at the thin line right above the 0 RPM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRI94 »</TD></TR><TR><TD CLASS="quote">Hey everybody! Any CELs? That might help to know.</TD></TR></TABLE>
If there were any check engine lights showing up on these cars, don't you think they'd investigate that before posting up about their problem. Atleast lets hope so..
Mike
Mike
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22ame »</TD></TR><TR><TD CLASS="quote">Its more than likely a TPS problem, on the back side of your intake manifold there is a plug (TPS plug), make sure that is together firmly and you wont have nemore idling problamos
Wouldn't this cause a CEL? Not everybody investigates before they post. So who has a CEL and who doesn't?
Civic4Doors: Did you just put an air intake and exhaust on or did you put on an entire I/M and exhaust manifold/header. Is your vaccumm line hooked up properly. More detail please.
</TD></TR></TABLE>Wouldn't this cause a CEL? Not everybody investigates before they post. So who has a CEL and who doesn't?
Yea there is no CEL's showing up at all,and i just put the intake pipe,not the manifold sorry for not putting that,but i will check the TPS tomorrow and try the zip tie and see if that helps.But why would it idle right during a cooler night,and during the day it is way low?
