95 hb h22
Old Mar 20, 2004 | 01:35 PM
honda99prelude's Avatar
Default 95 hb h22
im gonna be gettin a hb with a h22 in it but it needs to be finished it has no wiring harness or ecu.. what harness should i use?
Old Mar 20, 2004 | 01:54 PM
Discosteak's Avatar
Default Re: 95 hb h22 (honda99prelude)
i belive you can use an ex harness but im not 100%. does hasport make a converion harness for that swap?. it also depends an the OBD series the ecu and connectors are
Old Mar 20, 2004 | 02:07 PM
what do i need to do to get it runnin? what harness is eziest and what computer??
Old Mar 20, 2004 | 05:59 PM
Newman's Avatar
New User
Use the stock OBD-1 Civic harness and extend the wires as needed, then plug into the shock tower and run any additional lines (such as VTEC, EGR, EVAP, knock, or whatever else you want to run that your car doesn't already have ran in the chassis.
patroick67
Aug 31, 2011 10:08 AM
95accord8966
Nov 22, 2007 04:05 PM
grimple1
May 15, 2004 11:00 PM
civichb97
Dec 9, 2002 01:22 PM
