EK to EG suspension Qs
Old Oct 21, 2001 | 12:08 PM
555R's Avatar
Default EK to EG suspension Qs
will the EK lower control arms fit the EG
what i want to do is run the Apexi N1 coilovers
and rear lower control arms from an EK
and run it on my EG
is this doable?
its a 93 Si that I want to do this to
please let me know asap
thanks
Old Oct 21, 2001 | 12:24 PM
killingtime's Avatar
Default Re: EK to EG suspension Qs (555R)
Well, I put a 00 Civic Si Coupe suspension into a 92 Civic Si HB,
lessons learned:
Entire rear swapped, except read LCA's - I ended up putting GSR LCAS's in - the 00 Civic Si LCA in the rear WILL NOT FIT (it its 1.5- 2"'s too long).
Also, in the front, ONLY the front knuckle assembly (hub assy, rotor, caliper) swapped, all ofhter componented were stock 92 Civic Si HB.
Sorry, hope this helps,
Demian
johnegcy
Dec 29, 2015 06:35 PM
Ariddle25
11
May 3, 2011 05:58 AM
BrianFreels
May 4, 2009 01:36 PM
tomato_racing
Suspension & Brakes
Mar 20, 2006 10:24 AM
i20444406
Mar 13, 2005 09:48 PM
