[HELP] can i install EK suspension to EG and EG suspension to EK?
Re: [HELP] can i install EK suspension to EG and EG suspension to EK? (i20444406)
not on the back unless you swap the rear lower control arms around with it besides that yes it will bolt right on
Re: [HELP] can i install EK suspension to EG and EG suspension to EK? (Mr.Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Hatch »</TD></TR><TR><TD CLASS="quote">I have 93 Si rear discs on my 99.
So the answer is yes you can.</TD></TR></TABLE>
That doesn't mean anything.
You can swap EG suspesion on EK (except you will need to shim out the rear shock between shock and LCA). But you can't do EK to EG because you will have nowhere to mount brake lines upfront, and you won't be able to fit the rear shock over the LCA.
you can do eg to ek easily
for ek to eg, you need to be creative
- front bolts in, zip tie brake lines on
- rear bolts in, just need to cut down the middle lca bushing about 1/4" on both sides maybe more, i forgot
i did this last week, no problems
KillBot
03-12-2005 10:56 AM
