piston fitment questions....
Old Mar 19, 2004 | 04:33 PM
ReV LiMiT's Avatar
Default piston fitment questions....
i got a b16a in my car and i bought itr pistons bored .25 over. i was wondering if the stack of the of piston is too big for this particular engine. should i just forget about using the b16a block and use a 1.8 liter block like an ls and bore it out and do ls/vtec?
also, using the itr over bored pistons, should i stick with the b16 head or use a gsr head? i heard the gsr heads have differently positioned valves...so there is a possibility of the valve hitting the piston. what would be a better choice?
thanks
Old Mar 20, 2004 | 05:05 AM
eghonda's Avatar
Default Re: piston fitment questions.... (93sir)
using stock itr pistons in a b16a would lower your compression, i'm not sure about .25 over tho. step it up to a 1.8 or 2.0
fv8s
Dec 15, 2009 09:56 PM
ls_vtec_crx
Dec 17, 2003 03:01 PM
CanuckCRX
May 14, 2003 07:49 PM
:jdmshmaydm:
Jan 2, 2003 06:32 PM
3rdGteg
Sep 24, 2002 07:58 PM
