Engine replace..Do I have to pull tranny too
Old Oct 21, 2001 | 03:57 AM
SUis1's Avatar
Default Engine replace..Do I have to pull tranny too
I am pulling the Engine (D16Z) on a 5G HB Si and replaceing it with a lower milage one. The helms manual says you have to remove the engine and tranny together then replace......Can I save a few steps and leave the tranny in and just replace the engine? Thanks
Old Oct 21, 2001 | 05:16 AM
Big James's Avatar
New User
Default Re: Engine replace..Do I have to pull tranny too (SUis1)
Nope. That would actually be harder to do. Yank them both.
Old Oct 21, 2001 | 06:55 AM
owen_the_soyboy's Avatar
what? no?
well, I beg to differ, but I am no expert on D series stuff...
I figured you may be able to drop the tranny -
1) pull it off and move it away from the block.
2) then lift the motor out and replace with new freshie motor.
3) bolt tranny up to new motor.
4) done.
hmm, I had heard of people doing just this, especially when swapping the same motor for a newer or built one of the same engine code.
when you do a clutch install, it is possible to remove the motor at that point, so I do not know why you couldnt swap motors while the tranny is just pulled aside but still under the car.
Old Oct 21, 2001 | 08:06 AM
Big James's Avatar
New User
Default Re: Engine replace..Do I have to pull tranny too (owen_the_soyboy)
You can do that. However, it is far easier to remove the tranny once it is outside of the car. Also, you will need a way to hold the tranny from below, and yank the motor from above. You are in effect still removeing the tranny, you are just doing it before you remove the motor, which is harder.
Old Oct 21, 2001 | 08:12 AM
Honda318dx's Avatar
Default Re: Engine replace..Do I have to pull tranny too (Big James)
I agree, its much easier to swap motor/trannies outside at one time.. Its gonna be more work to drop the tranny out while it is still in the car if you are gonna take the motor out anyways..
Old Oct 21, 2001 | 10:27 AM
court's Avatar
25 Year Member
Default Re: Engine replace..Do I have to pull tranny too (Honda318dx)
hx man changed the motor out while leving the trans, he said it was much easier than swapping
Old Oct 22, 2001 | 01:11 AM
GZR4DR's Avatar
Default Re: Engine replace..Do I have to pull tranny too (court)
well HX mans on crack. I have done so many swaps its not even funny. And pulling a motor is almost as easy as swapping the trans. Plus its a sinch to swap a trans out of a car. Just pull the motor, then swap the trans over and your set. You will save time in the long run.
Old Oct 22, 2001 | 01:47 AM
martini's Avatar
honestly, there is no reason to NOT remove the tranny, it's not going to save any time or effort. It's much easier take the tranny on/off when you aren't lying on your back (ie, when the engine isn't in the car). Just pull it all.
Old Oct 22, 2001 | 08:44 AM
Spade's Avatar
Default Re: Engine replace..Do I have to pull tranny too (martini)
Man, pull the whole thing that way you can inspect the flywheel and clutch and replace it all back on without having to bend in funny directions. Plus, you can look at everything and make sure there isn't something else that is going to cause you problems.
Old Oct 22, 2001 | 08:56 AM
JUNIOR's Avatar
Default Re: Engine replace..Do I have to pull tranny too (Spade)
i agree pull the whole thing out and make sure there are no problems..
Old Oct 22, 2001 | 09:03 AM
3rdShift.org's Avatar
New User
Default Re: Engine replace..Do I have to pull tranny too (biggest_dookie)
Pull the whole motor... you are already going to have removed damn near everything that is connected to remove the block. When you chain up the motor, offset the center link toward the tranny side & remove it somewhat crooked to the right to clear the mounts. Removing the axles & the shift linkage will probably be the hardest part. The correct size pickle fork should be used to remove the axles and correct size punch and an air hammer with the correct punch should be used to remove the pin out of the shift linkage. You will save time in the long run by not having to crawl under the car & support both the motor & the tranny as you disconect them, since there is not an independent "engine" mount on the left, whereas the tranny mount holds the left side.
HTH
Rich
krysted9354
21
Nov 14, 2008 12:57 PM
MacGryder
Apr 17, 2008 11:03 PM
Rod.
Jan 20, 2004 07:24 PM
Shaun
Apr 8, 2003 07:49 PM
Inaniac
28
Oct 20, 2002 11:36 AM
