EGR Valve Excessive Flow
Old Mar 19, 2004 | 07:25 AM
Ricey McRicerton's Avatar
Default EGR Valve Excessive Flow
Hey guys, I don't come in here very often, but I have a quick ?.
One of my friends has a Protege and she got a Cel. I have some checking software so I took a look at it. The Code says "EGR Flow Excess Detected". She already had somebody take it out and clean it. What I think is wrong, is that it's not closing off. Anybody have any ideas?
Old Mar 19, 2004 | 09:11 AM
Proper's Avatar
Default Re: EGR Valve Excessive Flow (Ricey McRicerton)
If the EGR is not closing all the way will run EXTEMELY rough at idle. (If it will even idle at all. But at cruising speeds and under load will smooth out. The problem would mare than likely be the poppet valve inside the EGR itself. Meaning it will need to be replaced. Good Luck
-Proper
d_EG COUPE
19
Jun 21, 2009 07:02 PM
JBirch_97Prelude
Mar 26, 2007 08:43 AM
jdmboy
Sep 6, 2005 03:30 PM
allmotor2000
May 20, 2002 07:35 AM
