What Piston to wall clearance
Old Mar 18, 2004 | 07:42 PM
1BadCvC's Avatar
Default What Piston to wall clearance
My b18c5 is bored to an 85mm, with JE 11.5:1 (12:1 with the headgasket) and also sleeved. The shop workin on the motor now is sayin there is around 6000ths, however i took it to my machine shop and we read them all around 38-4200ths. What would be best?
Old Mar 18, 2004 | 09:08 PM
civicsitek GanGsTa's Avatar
Default Re: What Piston to wall clearance (1BadCvC)
optimal for all motor is in the 2.9-3.2 region if its more than 3.5 then it needs to be bored
Old Mar 28, 2004 | 12:25 AM
110 South's Avatar
The spec sheet of the piston should list what the wall clearance is. A lot of the time, JE pistons have a 4 thousanths PTWC.
Old Mar 31, 2004 | 08:33 AM
1BadCvC's Avatar
Default Re: What Piston to wall clearance (110 South)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 110 South &raquo;</TD></TR><TR><TD CLASS="quote">The spec sheet of the piston should list what the wall clearance is. A lot of the time, JE pistons have a 4 thousanths PTWC.</TD></TR></TABLE>
well that is a relief, the machine shop had a shop manager at a local honda dealer come over and mic the block, he came up with 3.9 thousandths as the most PTWC, so i think im in the clear. Thank you guys
Old Mar 31, 2004 | 09:31 AM
mattssi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1BadCvC &raquo;</TD></TR><TR><TD CLASS="quote">
well that is a relief, the machine shop had a shop manager at a local honda dealer come over and mic the block, he came up with 3.9 thousandths as the most PTWC, so i think im in the clear. Thank you guys</TD></TR></TABLE>
Now to find some high octane gas, good luck with your setup!
Old Mar 31, 2004 | 09:42 AM
1BadCvC's Avatar
Default Re: What Piston to wall clearance (mattssi)
lol, thank you
rh76pogi
34
Mar 22, 2008 09:00 AM
.adam.
Nov 21, 2007 02:39 PM
hardparked_ehtwo
Jun 10, 2007 08:42 PM
CR-V-tech
Nov 17, 2005 05:18 PM
crx1856
Nov 3, 2003 05:10 AM
