Vitara piston to wall clearance
Old Jun 7, 2007 | 03:09 PM
hardparked_ehtwo's Avatar
Default Vitara piston to wall clearance
The machine shop told me my piston to wall clearance as of now is already .005" and recommends me to go with oversize pistons but thats not an option for me right now. OEM service limit is only .002". Is this going to be ok and will there be any problems down the road? I don't know what the recommend clearance for vitara pistons are, but if any has gone thru a similiar situation can chime in? thanks
Old Jun 7, 2007 | 03:22 PM
stockb18c's Avatar
might here some slap
Old Jun 7, 2007 | 03:32 PM
Default Re: (stockb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockb18c &raquo;</TD></TR><TR><TD CLASS="quote">might here some slap</TD></TR></TABLE>
Yeah he said I'll have some slap during cold start..
Old Jun 7, 2007 | 04:26 PM
aj99si's Avatar
Default Re: (ehtwo)
.005 is way to much clearance for a cast piston. you are going to have to go oversize.
Old Jun 7, 2007 | 04:31 PM
confucioussae's Avatar
Default Re: (aj99si)
there is plenty of debate on this subject going on around td16.com
http://turbod16.com/viewtopic.php?t=34073
^ this thread is about a guy who has a .008 piston to wall clearance read these through. it might help clear up questionss
ANOTHER
http://www.turbod16.com/viewtopic.php?t=31192
Old Jun 7, 2007 | 05:19 PM
Default Re: (confucioussae)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by confucioussae &raquo;</TD></TR><TR><TD CLASS="quote">there is plenty of debate on this subject going on around td16.com
ANOTHER
http://www.turbod16.com/viewtopic.php?t=31192</TD></TR></TABLE>
Thanks
Old Jun 7, 2007 | 06:16 PM
fast2camciv's Avatar
youll be fine, i ran .004 on mine and it slapped a tiny bit...i have heard worse on forged piston cars. and yes jfk_78 runs .008 on his car and puts out the most of anyone using vitaras...thats gotta speak for something
Old Jun 7, 2007 | 06:19 PM
Jared's Avatar
this is apparently a problem with vitaras because they are undersized to start.
Old Jun 7, 2007 | 06:45 PM
Default Re: (Jared)
fjt said I can exchange for some 76mm, but will that be fine on stock sleeve? or should I just stick with the 75mm and hopefully have pwc at around .0055"- .006" after a slight hone?
Old Jun 7, 2007 | 06:50 PM
Jared's Avatar
OMG, that one guy is at .008". Is he planning on making 1200hp?
Old Jun 7, 2007 | 06:51 PM
Default Re: (ehtwo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ehtwo &raquo;</TD></TR><TR><TD CLASS="quote">fjt said I can exchange for some 76mm, but will that be fine on stock sleeve? or should I just stick with the 75mm and hopefully have pwc at around .0055"- .006" after a slight hone? </TD></TR></TABLE>
yes, you will need to bore/hone though... then again, jfk ran on .008 without any problems..
from what i hear, .004 is best on these suckers
Old Jun 7, 2007 | 07:05 PM
SovXietday's Avatar
Mine is around .005, sounds like a deisel but works just fine.
Old Jun 7, 2007 | 07:23 PM
litovi3tboi503's Avatar
Default Re: (SovXietday)
Go with .01" clearance you will be golden!
Old Jun 7, 2007 | 07:26 PM
Jared's Avatar
Default Re: (litovi3tboi503)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litovi3tboi503 &raquo;</TD></TR><TR><TD CLASS="quote">Go with .01" clearance you will be golden! </TD></TR></TABLE>
I hope you are kidding.
Old Jun 7, 2007 | 09:08 PM
Default Re: (fast2camciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast2camciv &raquo;</TD></TR><TR><TD CLASS="quote">youll be fine, i ran .004 on mine and it slapped a tiny bit...i have heard worse on forged piston cars. and yes jfk_78 runs .008 on his car and puts out the most of anyone using vitaras...thats gotta speak for something </TD></TR></TABLE>
Your car was my inspiration
Old Jun 7, 2007 | 10:29 PM
Default Re: (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">
I hope you are kidding.</TD></TR></TABLE>
why would i be kidding
Old Jun 7, 2007 | 10:32 PM
.RTErnie's Avatar
becauase .01" is TEN THOUSANDTHS of an inch... most forged pistons install anywhere from .0045-.0055 and higher depending upon how much heat you're going to put into the piston (expand via Horsepower)
Old Jun 7, 2007 | 10:46 PM
Default Re: (.R T E r n i e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .R T E r n i e &raquo;</TD></TR><TR><TD CLASS="quote">becauase .01" is TEN THOUSANDTHS of an inch... most forged pistons install anywhere from .0045-.0055 and higher depending upon how much heat you're going to put into the piston (expand via Horsepower) </TD></TR></TABLE>
.01" is a HUNDREDTH ( .1 tenth, .01 hundredth, .001 thousandth, .0001 ten thousandth)
....you are right though! .01 is WAYY to big of a gap to be running, OP will be lucky if his car goes anywhere and has oil by the end of the week if he dares put this in his car.
Old Jun 7, 2007 | 11:05 PM
.RTErnie's Avatar
....you are right though! .01 is WAYY to big of a gap to be running, OP will be lucky if his car goes anywhere and has oil by the end of the week if he dares put this in his car. </TD></TR></TABLE>
<FONT SIZE="4"><FONT COLOR="red">YEAH NO ****...
ONE HUNDREDTH= 10 THOUSANDTHS</FONT></FONT>
Old Jun 8, 2007 | 06:16 AM
why would i be kidding</TD></TR></TABLE>
Ignore him he's just messing around.
Old Jun 8, 2007 | 07:10 AM
Joseph Davis's Avatar
Chill, homeslice. Simple math eludes some people. Further, their inability to measure in the commonly accepted units any automotive machinist is conversant with shows how little they know. Arguing on the internets with them will not change this.
Finding their home address, and killing them before they can breed, will make the world a better place, though.
Old Jun 8, 2007 | 07:19 AM
.RTErnie's Avatar
Default Re: (Joseph Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis &raquo;</TD></TR><TR><TD CLASS="quote">
ha...for some reason I felt compelled to break out the bolt, size=4, and the almighty color=red.
Old Jun 8, 2007 | 09:59 AM
fjt's Avatar
fjt
Mine had .006 clearance and it ran fine for the 2 yrs i had it. Never had problems of blow by and always my Compression test numbers were even.
JFK's car has .008 clearance and he holds the record for most hp out of the vitaras and stock sleeves (443whp)
BTW: I should be receiving 75.5mm vitaras in around a week or two and a second batch by mid July.
Old Jun 10, 2007 | 08:42 PM
i just built another block for someone, it had .0045 clearance...customer says it runs like a champ...i also over saw the build of another block that runs .006 and it is running flawless as well....on the 2nd motor it really has no audible slap at all...not sure why, but its very quite.
Default Re: (ehtwo)
Your car was my inspiration </TD></TR></TABLE>
thanks good luck with yours!!
AaronJ
May 1, 2008 05:42 PM
.adam.
Nov 21, 2007 02:39 PM
garyc17
Jun 12, 2007 02:26 AM
dude_123
Sep 29, 2005 08:02 AM
Sport_Injected
Jul 29, 2004 03:15 AM
