Popping sound from exhaust when cranking
Old Mar 18, 2004 | 10:27 AM
infinate bound's Avatar
Default Popping sound from exhaust when cranking
My car is not starting...like i said in earlier post i do have spark, compression, fuel pressure, the fuel pump is engaging, and i peeked in the oil cap hole while my friend was cranking the car and everything was moving and working properly!! When i crank the car over there is a popping sound every couple of seconds coming from the exhaust...ignition timing???
Old Mar 18, 2004 | 10:43 AM
InjectedPerformance's Avatar
We sell parts.
Default Re: Popping sound from exhaust when cranking (infinate bound)
firing order
Old Mar 18, 2004 | 10:44 AM
ramennoodles's Avatar
this happened to me before, for me it was when I change the timing belt, I was like a tooth off when I put the belt on.
Old Mar 18, 2004 | 11:01 AM
Default Re: Popping sound from exhaust when cranking (600gixxer)
I do need to check the firing order...if it is that how do i correct the problem??? I do i check to see if it is firing in the correct order??
Old Mar 18, 2004 | 12:08 PM
jazz215's Avatar
Default Re: Popping sound from exhaust when cranking (primo8998)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primo8998 &raquo;</TD></TR><TR><TD CLASS="quote">firing order</TD></TR></TABLE>
same thing happen to me.. i accidentally switched 2 of the spark plug wires.
Old Mar 18, 2004 | 01:23 PM
We sell parts.
Default Re: Popping sound from exhaust when cranking (jazz215)
put the motor at TDC. Take off the distributor cap. Look at the rotor button, where it points is number one cylinder. Then 1342 clockwise.
Old Mar 18, 2004 | 01:43 PM
MightyMouseTech's Avatar
What were you doing to the car BEFORE it started doing this......that JUST might give us a clue.....
[sigh]
Old Mar 19, 2004 | 03:54 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primo8998 &raquo;</TD></TR><TR><TD CLASS="quote">put the motor at TDC. Take off the distributor cap. Look at the rotor button, where it points is number one cylinder. Then 1342 clockwise.</TD></TR></TABLE>TDC#1 for the crank comes up on both exhaust & compression. You can't tell which is which without seeing the cams. It might be #1 or it might be #4...
Old Mar 19, 2004 | 07:22 AM
cvc96honda's Avatar
New User
What year engine/car do you have? If it's an 88-91 and the plug wires are in the right order, check the rotor. On the 88-91 dist. the rotor can be installed 180 degrees off b/c that screw hole goes all the way through the shaft.
Old Mar 19, 2004 | 02:10 PM
bornAsleeper's Avatar
Default Re: Popping sound from exhaust when cranking (cvc96honda)
hmmmm, prolly something internal...did you actually run a compression test??? i bet not
sleet_22
Dec 9, 2013 02:09 PM
exit22lsv
20
Nov 5, 2008 07:11 AM
nighttrain33
Mar 23, 2008 01:38 PM
embidia1
Dec 17, 2007 06:14 AM
DetroitPOScivic
37
Jun 10, 2004 08:07 AM
