HAS THIS EVER HAPPENED TO ANYONE??
Old Mar 18, 2004 | 07:44 AM
rocco's Avatar
Default HAS THIS EVER HAPPENED TO ANYONE??
Well My car has a hard time going into gear in the higher revs,infact it grinds quite sometimes. When I press the clutch while its in gear,the car makes these tiny jerks about 5 times and stops and the clutch chatters like crazy.HAs this ever happened to anyone?
Old Mar 18, 2004 | 07:51 AM
Spade's Avatar
Default Re: HAS THIS EVER HAPPENED TO ANYONE?? (rocco)
syncros for the first part.
2nd part is not known to me at this time....what happens when your going 25 mph, you put the car in 5th gear and floor it?
Old Mar 18, 2004 | 07:53 AM
rocco's Avatar
Default Re: HAS THIS EVER HAPPENED TO ANYONE?? (Spade)
never tried it,someone told me it might be that either clutch or flywheels is bent
Old Mar 18, 2004 | 07:54 AM
xerox445's Avatar
souds like your PP is fuxored, open that up asap. It might have backed off of the flywheel. Don't ask how i know this
Old Mar 18, 2004 | 08:00 AM
SpoolinEK9's Avatar
From: Seattle/Ligonier, WA/PA, United States of Honda
ya syncro defently im not sure other than that listen to xerox hes most likely right. i know what its like kinda my synco is fucked from 1st 2 second around 6k rpms
Old Mar 18, 2004 | 08:21 AM
rocco's Avatar
Default Re: (SpoolinEK9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolinEK9 &raquo;</TD></TR><TR><TD CLASS="quote">ya syncro defently im not sure other than that listen to xerox hes most likely right. i know what its like kinda my synco is fucked from 1st 2 second around 6k rpms</TD></TR></TABLE>I really dont understand what your saying dude.So do u think its a syncro or the clutch?
Old Mar 18, 2004 | 08:26 AM
B_CRUZ!'s Avatar
noit to be a dick but make your thread title more specific. good luck and open up your tranny asap.
2. PLEASE MAKE THE TITLE TO YOUR TOPICS VERY CLEAR AND TO THE POINT.
Titles with just "Question here..." or "who knows..." or "HELP NEEDED!!! probably won't garner enough interst from the people who might actually be best to answer your question. I see these type of threads sink rapidly and then the thread starter rips on H-T for sucking because nobody answered their question. TOPICS WITH VAGUE TITLES WILL EITHER BE EDITIED BY ME OR SIMPLY DELETED.
it would just make the search function actually better.
Modified by B CRUZ at 10:29 AM 3/18/2004
Old Mar 18, 2004 | 08:42 AM
8200RPM's Avatar
local hippie
Well, as far as the grinding when you try to put it in gear its most likely the syncros. My 3rd gear grinds pretty bad, the higher the rpms the worse right?
Old Mar 18, 2004 | 09:15 AM
rocco's Avatar
Default Re: HAS THIS EVER HAPPENED TO ANYONE?? (8200RPM)
yea but what about the clutch chattering,these problem have to be linked somehow
Old Mar 18, 2004 | 09:16 AM
rocco's Avatar
Default Re: HAS THIS EVER HAPPENED TO ANYONE?? (B CRUZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B CRUZ &raquo;</TD></TR><TR><TD CLASS="quote">noit to be a dick but make your thread title more specific. good luck and open up your tranny asap.</TD></TR></TABLE>Why so no one will bother even clicking the thread, nothing against you man i just find it hard getting feedback if i put the tech in the title
Old Mar 18, 2004 | 09:51 AM
Happyman's Avatar
Well the clutch problem could be related to your grinding problem. If the clutch isn't unengaging(probably not a word but i can't think right now) then of course the gears will grind. And listen to Xerox, his clutch was doing the same thing a few weeks ago.
Old Mar 18, 2004 | 10:06 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocco &raquo;</TD></TR><TR><TD CLASS="quote">Why so no one will bother even clicking the thread, nothing against you man i just find it hard getting feedback if i put the tech in the title </TD></TR></TABLE>
You either follow the rules, or I lock/delete your topics.
Simple as that.
You're being extremely selfish when you try to find help without putting the subject matter in your title, because if you get help nobody else with the same problem will ever get help.
Also if you had done a simple search under "tranny grinds" or "tranny grinding" you'd have probably found plenty of info, but instead you bascially started yet another tranny grinding topic.
BTW:
I found at least 7 other topics that describe exactly what you're talking about by using the key words "tranny grind" under archived topics in all forums.
In short you need to rebuild your tranny and replace the worn synchros that are causing your grinds.
z51LS2
Apr 16, 2006 05:17 PM
preluda
Aug 22, 2005 09:50 PM
civicstar
Aug 22, 2005 06:41 PM
Komptech
Mar 29, 2005 07:35 PM
Inextricabledrvr
Jun 18, 2004 10:39 AM
