Tranny issues!
Munkyw3rkz.webs.com
ok we just finished a B20Vtec swap in a EK hatch! the swap was removed form another EK and put into the hatch!
well everything is up and running. new OEM pressure plate and disc as well as the throwout bearing
so we drive it out of the garage and down the street. we get to the corner. go around the corner go into 2nd gear and pull the the clutch pedal out and nothing!
like the clutch isn't engaging.
we bled the clutch 5 times....the tranny goes into gears, the shift linkage is on A OK! the slave cylinder is on and moving the fork!
I have thought of everything there is that i know! please help! thanx in advance
i dunno but maybe your throwout arm slipped over your thorwout bearing? not even sure if that is possible though. i garauntee your going to have to take off the tranny and find out
