Serious tranny problem, 01 MDX
Old Mar 17, 2004 | 03:42 PM
Chiovnidca's Avatar
Default Serious tranny problem, 01 MDX
A freind was driving her MDX about 60mph, heard a noise just as the front wheels locked up. Tires have flat spots to prove it. One of the other techs tore it down and found this:
Looks like 2nd gear got a little hot.
Cracked the case too.
Anybody seen anything like this? I think it's the same tranny as the Pilot, weve sold alot of them and havn't seen a single transmission problem with one.
Old Mar 17, 2004 | 05:15 PM
Kal's Avatar
Kal
Default Re: Serious tranny problem, 01 MDX (Chiovnidca)
wow wtf happened. i haven't heard of any pilot doing that yet
Old Mar 17, 2004 | 07:11 PM
Dan GSR's Avatar
Default Re: Serious tranny problem, 01 MDX (kxkal)
wow, thats some nasty ****
Old Mar 19, 2004 | 02:04 PM
Chiovnidca's Avatar
Were thinking they got it stuck in the snow at some point and the heat weakened the gears.
Old May 2, 2004 | 12:31 PM
Chiovnidca's Avatar
Default Re: (Chiovnidca)
Well, turns out to be yet another transmission problem from Honda.
From service bulletin 04-021 for Odyseys and Pilots:
Certain operating conditions can result in heat buildup
between the countershaft and secondary shaft second
gears in the automatic transmission. Without enough
oil flow to dissipate heat, prolonged operation under
these conditions can eventually result in decreased
material strength. In higher mileage vehicles, this can
result in gear tooth chipping or, in very rare cases, gear
breakage.
In most cases, transmission noise will indicate a
problem, however it is possible for the transmission to
become locked without warning. A locked transmission
could result in a crash.
Old May 2, 2004 | 12:34 PM
blah13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">Well, turns out to be yet another transmission problem from Honda.
breakage.
could result in a crash.</TD></TR></TABLE>
Owned yourself, but at least now you know. Is this a recall issue or just warranty?
Old May 2, 2004 | 12:37 PM
Chiovnidca's Avatar
Default Re: (blah13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blah13 &raquo;</TD></TR><TR><TD CLASS="quote">
Owned yourself, </TD></TR></TABLE>
How's that? Yes, it's a recall.
Old May 2, 2004 | 02:13 PM
Kal's Avatar
Kal
wow Honda has really been getting bad with their reliability nowadays... maybe it's because those two cars are manufactured here?
Old Jan 31, 2006 | 10:18 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: (Kal)
No, the 01 Civic with its trash D17 had overheating issues with the a/t.
Old Feb 1, 2006 | 10:52 AM
msmotorsports's Avatar
Default Re: (Kal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal &raquo;</TD></TR><TR><TD CLASS="quote">wow Honda has really been getting bad with their reliability nowadays... maybe it's because those two cars are manufactured here? </TD></TR></TABLE>
These damn companies nowdays are trying to cut corners to make more profits. In the end they just f*ck themselves over by having to recall and fix all these problems. Once you lose your reputation you can definitely expect to see a drop in sales. It's sad to see this happen because imports in general have the rep for being very reliable. ****, pretty soon we'll start seeing employee discount sales from Honda and Acura.
JunIntegra
Honda S2000
19
Oct 20, 2008 10:56 AM
GYChris
19
Sep 13, 2007 05:50 PM
5thgenbb6
Jun 28, 2007 11:05 AM
02NJHondaep3
24
Dec 24, 2003 05:51 PM
