Changed ecu, and vtec was at a different point. Soposedly the same ecu?
Old Mar 17, 2004 | 10:26 AM
streetlvlhatch's Avatar
Default Changed ecu, and vtec was at a different point. Soposedly the same ecu?
I have a p72 running my ls/vtec with a gsr head/manifold. I had it running fine, and it hit vtec at 4400. It was a noticible change in sound. I just tried to put in an ecu i was told was a p72 (stamp missing) and it didnt hit till 5700. What is goin on? Also, the knock sensor code did not go off like it used to with the old ecu. Any help? Can pics of the internals help?
Old Mar 17, 2004 | 11:26 AM
Smith Wise's Avatar
Default Re: Changed ecu, and vtec was at a different point. Soposedly the same ecu? (streetlvlhatch)
vtec is now different, then you have a different ecu... can't really tell you what it is from internal shots... bump for you
Old Mar 17, 2004 | 03:14 PM
Default Re: Changed ecu, and vtec was at a different point. Soposedly the same ecu? (Jswpstdoff)
This is confusing me. I though vtec on a p28 is at 4800 anyways? What other obd1 ecu could it be? B16?
Old Mar 17, 2004 | 05:50 PM
RedlinedVTEC's Avatar
Well with no sticker you can't tell from the outside, pop it open to see if it's stock or reprogrammed (look for 28 pin eprom to see if it's reprogrammed which it likely is with the lack of ks cel). To me just from how you described it, it sounds like it's probably a chipped p28 (could be a chipped p72 or p30 as well, but p28 is the most common).
em1gangsta
18
Mar 28, 2016 05:36 PM
mpls
Feb 2, 2009 01:31 PM
Whiteintegra
Jul 14, 2006 05:16 PM
kihun_cha
Dec 8, 2005 10:38 PM
accordm3
Oct 25, 2004 09:44 AM
