doing major work on my car with timing belt.. need sugestions
Old Mar 17, 2004 | 07:27 AM
radzer0's Avatar
Default doing major work on my car with timing belt.. need sugestions
im getting my timing belt changed because it broke the other day.. its a b18a motor and im wondering if theres anything else i should get done at the same time
im also getting the cam plug and the valvestem seals changed at the same time and am gonna look into the waterpump
car has 114k miles on it.. are there any other parts i should get the mechanic to check out or anything maybe change any cheap parts that people dont change because of all the work it needs to do it?
Old Mar 17, 2004 | 07:33 AM
92b16aTurbo's Avatar
Default Re: doing major work on my car with timing belt.. need sugestions (radzer0)
If your timing belt broke, you should have your head looked at. You most likely bent some valves. This happened to me a while back, and it turned out that I had 8 bent valves. You should change the water pump, and tensioner while you're in there. If you want to do some fun stuff while the head is off (or accessible), you should look into some cams, and valve springs. Crower makes a decent set for a decent price.
Good luck!
Old Mar 17, 2004 | 07:43 AM
radzer0's Avatar
Default Re: doing major work on my car with timing belt.. need sugestions (92b16aTurbo)
no money for cams...
does the tentioner wear out quick or something?
as far as i can tell.. nothing inside the motor got damaged.. i was sitting at a redlight and the motor just killed...no noises or anything.. and when i pulled the valvecover off everything looks good
as for the water pump.. how many miles do they usualy last?.. because anything more i want to get done i gotta pay for.. and is there anything i can look at on the waterpump to decide if it needs changing or not?
Old Mar 17, 2004 | 08:13 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by radzer0 &raquo;</TD></TR><TR><TD CLASS="quote">... as far as i can tell.. nothing inside the motor got damaged.. i was sitting at a redlight and the motor just killed...no noises or anything.. and when i pulled the valvecover off everything looks good</TD></TR></TABLE>Well, then you're lucky. Actually, at idle you've got a better chance, maybe the cam just stopped with all the valves closed. But you can't always tell if they're bent just from the valve cover. You'll find out soon enough...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by radzer0 &raquo;</TD></TR><TR><TD CLASS="quote">as for the water pump.. how many miles do they usualy last?.. because anything more i want to get done i gotta pay for.. and is there anything i can look at on the waterpump to decide if it needs changing or not?</TD></TR></TABLE>Not really. When I changed my timing belt, I inspected the pump & it looked good. The bearings were nice & smooth, so....
But 15 months later it was leaking. YMMV. I wasn't too angry, because I did the work myself. But it still killed an afternoon when I coulda been doing something else. The reason you do them together is once the timing belt is off, it's only 5 more bolts for the pump. If you're paying shop labor, that's a LOT.
Old Mar 17, 2004 | 08:19 AM
radzer0's Avatar
if you say valves closed... i dont know if this makes any diffrence.. but the cam gears were both with the up mark within like 1/2cm of top..
Old Mar 17, 2004 | 08:20 AM
BeerMan's Avatar
Default Re: doing major work on my car with timing belt.. need sugestions (JimBlake)
I would definately go with a new water pump, might as well. I would also think about an oil pump, but that's just me. I love new shiny parts on my engine and sometimes I can't help myself but replace parts when given the opportunity.
Good luck on those valves too.
edit: just realized you are having someone else do the work. Maybe forget the oil pump and save the labor costs.
Old Mar 17, 2004 | 08:23 AM
radzer0's Avatar
Default Re: doing major work on my car with timing belt.. need sugestions (BeerMan)
im still thinking about the waterpump.. the oil pump is no chance tho.. its like $230 for a aftermarket one
Old Mar 27, 2004 | 07:37 PM
radzer0's Avatar
when the guy pulled the thing apart it had the factory waterpump.. 114k miles on it.. it was so fucked up i dont think it woulda lasted much longer.. it would move all directions like 0.5cm..
Old Mar 28, 2004 | 08:31 AM
suspendedHatch's Avatar
My water pump just went bad. 150k miles on a 1993.
Old Mar 29, 2004 | 04:37 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by radzer0 &raquo;</TD></TR><TR><TD CLASS="quote">when the guy pulled the thing apart it had the factory waterpump.. 114k miles on it.. it was so fucked up i dont think it woulda lasted much longer.. it would move all directions like 0.5cm.. </TD></TR></TABLE>Yeah, there's more than one way for them to fail. Had one on a '86 Jetta, where the bearings started getting loose. Once I took off the belt, I could wobble the pulley quite a bit. It made a rattling noise when the impeller hit the housing. But the seals weren't leaking. The pump on my Integra started leaking, but the bearings were still tight & smooth...
Old Mar 29, 2004 | 04:48 AM
radzer0's Avatar
mine wasnt leaking eather.. but it wouldnt hold up to another 40k miles or however long before another belt changed
so i put in a $30 waterpump
si90rex
17
Oct 9, 2010 08:08 PM
lilskud13
14
Mar 26, 2009 01:28 PM
dforemsky
Jan 25, 2007 02:21 PM
311
Jul 20, 2002 10:08 AM
g35driver
Feb 28, 2002 11:35 AM
