Problem: can't remove headlight housing to replace bulb
Old Oct 19, 2001 | 09:30 PM
gsr.sedan's Avatar
25 Year Member
Default Problem: can't remove headlight housing to replace bulb on 96 Accord
I need to change a bad bulb on my mom's 96 accord. How do you get the friggin plastic housing off so you can remove the bulb? I looks like you just have to twist it off, but the darn thing won't move
[Modified by gsr.sedan, 10:30 PM 10/19/2001]
Old Oct 19, 2001 | 10:24 PM
tensai's Avatar
New User
Default Re: Problem: can't remove headlight housing to replace bulb on 96 Accord (gsr.sedan)
lefty loosey righty tighty
Old Oct 20, 2001 | 01:28 AM
Big James's Avatar
New User
Default Re: Problem: can't remove headlight housing to replace bulb on 96 Accord (whiteconfusion)
It can be a real bitch to turn it. However, it does turn. You might have to remove some stuff from in front of the light so you can get a good grip. I have also had to get a socket extension to push on it with from the side.
Old Oct 20, 2001 | 02:06 AM
John's Avatar
New User
Default Re: Problem: can't remove headlight housing to replace bulb on 96 Accord (Big James)
although i'm quite certain WD-40 would work, however, i'm pretty certain your mechanic wouldn't be happy with your decision...
Old Oct 20, 2001 | 04:09 PM
4doorH22's Avatar
Those things are a bitch to unlock sometimes. What should be a 60 second job turns into half an hour of sweating, swearing, bruising, and bleeding.
Old Oct 20, 2001 | 04:15 PM
urbanlegend21's Avatar
New User
Default Re: Problem: can't remove headlight housing to replace bulb on 96 Accord (4doorH22)
unplug the wire from the bulb first then apply pressure tp the tab on the bottom of the black holding clip
Old Oct 20, 2001 | 05:33 PM
Gennady's Avatar
New User
Default Re: Problem: can't remove headlight housing to replace bulb on 96 Accord (urbanlegend21)
Exactly. Just apply constant pressure on that tab with your thumb and it will break loose. I wouldnt suggest WD-40 since its plastic and not metal. Carfull of the outter rim of the housing, you can cut your hand up pretty badly, I did.
Old Oct 20, 2001 | 08:52 PM
Bklyn TSi's Avatar
Banned
hahahahaa... bruising and bleeding is right! i got so fed up w/ my housing cap i broke it off w/ a flathead screwdriver
Old Oct 20, 2001 | 10:34 PM
4doorH22's Avatar
Default Re: Problem: can't remove headlight housing to replace bulb on 96 Accord (Stony TSi)
Yup, so did I, passenger side low beam. Ended up having to replace the entire headlight housing 'cause the bulb wouldn't stay in there. I should've just gotten the JDM one-piece units.
Old Oct 21, 2001 | 02:56 PM
mistikal07's Avatar
New User
twist very very hard counter-clockwise. the right headlight is pretty easy to get to but the left is a b****. for the left, i ended removing the battery and that black flappy thingy next to the headlight housing. my friend that tried to remove his bulb ended up cutting his hand because he twisted the bulb instead of the housing around it.. good luck.
Old Oct 21, 2001 | 05:38 PM
rsxr's Avatar
New User
Default Re: Problem: can't remove headlight housing to replace bulb on 96 Accord (mistikal07)
don't tell me, your putting in white riceboy lights...
Old Oct 22, 2001 | 03:23 PM
Gennady's Avatar
New User
Default Re: Problem: can't remove headlight housing to replace bulb on 96 Accord (rsxr)
Ok buddy, your just starting to **** me off on ever thread. Not everyone can pay the $500+ for a Xenon halogen conversion. I'd rather have whiter lights, than the regular yellow ones. Lay off.
Old Oct 23, 2001 | 09:22 AM
mike4's Avatar
New User
and a couple of finger nails and knuckles hahahaha !!!.
Old Oct 25, 2001 | 10:30 PM
gsr.sedan's Avatar
25 Year Member
Default Re: Problem: can't remove headlight housing to replace bulb on 96 Accord (mike4)
Hey everyone, I did finally get it off by first spraying it w/ WD-40 (thanks to my pops, who did it that night). After letting it sit for a fewminutes, it twisted right off. Dunreit was on the money.
Thanks for the posts folks.
Old Dec 22, 2003 | 09:01 AM
vtec.dc2's Avatar
back from the dead.. i ended up tapping with flat screw driver + hammer on edges of housing to make it unlock/lock.. worked well and easy.
Old Dec 22, 2003 | 11:30 AM
Bklyn TSi's Avatar
Banned
Default Re: Problem: can't remove headlight housing to replace bulb on 96 Accord (vtec.dc2)
Holy 2 year old thread batman! I posted in this thread in oct. 01.. Damn.
Old Dec 22, 2003 | 12:10 PM
Monkey Fing a Coconut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">back from the dead.. i ended up tapping with flat screw driver + hammer on edges of housing to make it unlock/lock.. worked well and easy.</TD></TR></TABLE>
holy **** how bored were u to find this unimportant common topic and bring it back...
Old Dec 22, 2003 | 07:23 PM
2+2=5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsxr &raquo;</TD></TR><TR><TD CLASS="quote">don't tell me, your putting in white riceboy lights...</TD></TR></TABLE>
another piece of proof that honda-tech is getting overrun by dumbass
Old Dec 22, 2003 | 07:29 PM
vtec.dc2's Avatar
Default Re: Problem: can't remove headlight housing to replace bulb on 96 Accord (Bklyn TSi)
lol.. housing wouldn't turn, so i thought i'll give good old search a try, while i didn't want to use oil, i found my own method and though i'd share for future reference.
slamstrom
Apr 12, 2017 04:50 AM
cpeters
May 2, 2015 03:31 PM
NOFX
17
Oct 11, 2008 04:25 PM
green27
Feb 12, 2005 08:01 PM
Spooled1.6L
Feb 9, 2004 10:52 AM
