Problem replacing a headlight
Old Mar 6, 2008 | 06:47 AM
cpeters's Avatar
Default Problem replacing a headlight
Good morning all,
One of my low beams has burned out on my accord, replacing it should be a no brainer right? Well is turning into a night mare, seems i cannot remove the light, i cannot get the collar to turn properly for me to remove the bulb and replace it. Any suggestions people?
Car specs are in my sig
Old Mar 6, 2008 | 08:51 AM
not-a-stang's Avatar
Default Re: Problem replacing a headlight (cpeters)
I hit mine with a screwdriver and light hammer blows. Be careful because the plastic looked brittle (heat-cooked?), but it did finally come loose.
Try hitting the lower ear/projection since that is where the collar seems to be designed to be turned from.
Old Mar 6, 2008 | 05:50 PM
hondadude's Avatar
I've had my share of problems with that plastic ring, tapping on it will sometimes get it to move. I have also used my heat gun [super blowdryer] to warm them up and get them to break loose.
I always put a little smear of silicone grease on the threads when going back together, because I hate to see someone else have to struggle with it in another 5-10 years.
Old Mar 7, 2008 | 04:23 PM
rirc's Avatar
Default Re: Problem replacing a headlight (hondadude)
disconnect the wire that is connected to the lightbulb first and then push in a little and turn anti-clockwise to take the bulb out.
Old May 2, 2015 | 03:25 PM
beaterproject's Avatar
might have to take the battery out if the headlight burnt out is on that side of your car. i did that with my 94 accord and it made things a lot easier and better angles on the back of the light.
Old May 2, 2015 | 03:31 PM
rockycat's Avatar
Hope in 7 years the op has a new bulb installed.
thunderboy
Nov 7, 2007 12:01 PM
sshan25
Mar 16, 2006 11:29 PM
barroom hero
Feb 20, 2004 12:15 PM
animated_life
Dec 27, 2003 12:03 PM
gsr.sedan
Dec 22, 2003 07:29 PM
