Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Trick to replacing the turn signal bulb on a 96 Odyssey
Old 10-08-2009, 09:35 AM
slamstrom's Avatar
Default Trick to replacing the turn signal bulb on a 96 Odyssey
I am having a hard time removing the turn signal housing to replace the bulb. Is there a trick to easily remove the housing so I can replace the bulb? Is it similar to replacing the turn signal bulb on a 94-97 Accord or do I have to remove the whole headlight assembly to get to the turn signal bulb?
Old 10-08-2009, 10:52 AM
NDNV's Avatar
Default Re: Trick to replacing the turn signal bulb on a 96 Odyssey
I think the easiest way is to access the turn signal bulb from removing part of the inner fender in the wheel well.
Old 10-10-2009, 05:14 PM
slamstrom's Avatar
OK. Finally got some time today, and was able to find an easy way to replace the turn signal bulb. The replacement bulb is 2057, not 2057A (A=amber). There is an amber lens in the housing, the bulb is clear. I took some photos and added step by step instructions on the photos for those who may be asking the same question in the future.
Old 04-12-2017, 04:50 AM
kemimich's Avatar
I know that this is an old thread, but THANKS Slamstrom! I couldn't get the housing out and was afraid I was about to break it. A quick google search brought up your thread and voila!
DarkStreetRacerX
Lighting
09-24-2007 06:50 AM
bmbrplt
02-07-2006 11:52 AM
lilredracer
10-26-2005 06:42 PM
gsr.sedan
12-22-2003 07:29 PM
Quick Reply: Trick to replacing the turn signal bulb on a 96 Odyssey
