Adjustable fuel pressure regulator vs. Electronic Air Fuel Controller?
Old Oct 19, 2001 | 07:46 PM
LshatchTurbo's Avatar
New User
Default Adjustable fuel pressure regulator vs. Electronic Air Fuel Controller?
In your guys opinions, its a adjustable fuel pressure regulator a cheap, or poor mans version of a Electronic air fuel controller? Your comments please
Old Oct 19, 2001 | 09:40 PM
FSTASNTZ's Avatar
Default Re: Adjustable fuel pressure regulator vs. Electronic Air Fuel Controller? (Zynentech)
Depends how much fuel you need. The S-AFC and V-AFC seem to excel at taking fuel away from the mix, but not very consistant on adding fuel. Usually both together make a good team. Add fuel with the FPR and fine tune with the AFC...
Jason
Old Oct 19, 2001 | 09:49 PM
New User
Default Re: Adjustable fuel pressure regulator vs. Electronic Air Fuel Controller? (FSTASNTZ)
hmmm interesting. YOu have any or heard any comments about HKS's AFC unit?
Old Oct 20, 2001 | 05:40 AM
FSTASNTZ's Avatar
I have heard about it from some Eclipse owners, and they are not too happy with it. They keep selling them and going to the S-AFC from APEXi...
Jason
Old Oct 20, 2001 | 10:23 AM
New User
Default Re: Adjustable fuel pressure regulator vs. Electronic Air Fuel Controller? (Teken)
hmm so what is the stock fuel pressure usually set at and what is the limit of the stock regulator?
Old Oct 20, 2001 | 10:34 AM
FSTASNTZ's Avatar
Depends what car you have as to what the pressure is at. As for max pressure, that depends on the fuel pump and its ability to keep up.
Stock regulator, it is not adjustable, so you have to replace it with an AEM unit, or but it and add the B&M unit. If that is a consideration, I suggest the AEM unit.
Jason
97grnrs
Dec 2, 2006 07:58 AM
onefstek
Nov 18, 2005 01:55 PM
toooslow
May 15, 2003 12:21 PM
db2b17a-R
Nov 21, 2002 05:24 PM
spun Vtec
Nov 7, 2002 09:27 AM
