Are there any gains from using a PG7 ecu on my d15b2/y7 mini-me?
Old Mar 16, 2004 | 06:33 PM
d15maverick's Avatar
Default Are there any gains from using a PG7 ecu on my d15b2/y7 mini-me?
Would this work well, or too much fuel? I have a pm6 from a 91 civic Ex running my motor at this moment, everything seems good so far. Power increase was dramatic. More than I expected, however, I heard that the pg7 has a higher redline and more aggressive fuel and timing maps. Now as far as I know, the redline is more to protect the valvetrain than the bottom end correct? With the y7 head I should be able to take it up past the 6500 rpm redline. Would I benefit from the few extra 100 rpms and extra fuel? TIA
Old Mar 16, 2004 | 06:35 PM
jedubz's Avatar
Depends. Both arent VTEC ecus. How is your VTEC kicking in?
Old Mar 16, 2004 | 06:54 PM
Default Re: (jedubz)
I don't have vtec. It's a d16y7 head. I know, im doing something a little different. This set-up is actually pretty good compared to what I have heard otherwise. I was just curious what would the pg7 do in terms of power? I was considering getting a y8 intake manifold and a Teg TB. Was just wondering will I be ok with the extra airflow with the pm6 or should I move over to the pg7? My engine is just a high compression non vtec sohc. I dont want to lean out and detonate. Any ideas guys?
Old Mar 16, 2004 | 07:05 PM
-16V-'s Avatar
Default Re: (d15maverick)
I think you should stick with the one u already have.
I think the pg7 has higher red line due to the fact there a dohc motor.
I could be wrong tho.
As far as the y8/tb swap im going to try the same thing, but im boring out my t/b to like 61mm.So let us know how it gos.
So i take it u notice a Huge gain in the mpfi swap?
Old Mar 17, 2004 | 08:29 AM
Yes I did. Made a big difference. I really think the head swap made the most though. I have had mpfi for mor than a year now. But after swapping the head two weekends ago, Ive been having so much fun. I recommend it
Modified by d15maverick at 5:54 PM 3/17/2004
Old Mar 17, 2004 | 01:52 PM
MatHadder's Avatar
Default Re: Are there any gains from using a PG7 ecu on my d15b2/y7 mini-me? (d15maverick)
Keep the PM6. It is easier to chip, which will allow you to make more power than the PG7 ever would.
Old Mar 17, 2004 | 03:57 PM
scdarksol's Avatar
I put it in my CRX Si and the check engine came on, put the Pm6 back, no problems. And it runs the same.
Old Mar 18, 2004 | 06:02 AM
undefinedcrx's Avatar
im with maverick. it may sound outlandish to you, but i gained a constant tenth through the 1/4 mile, and a constant 1.5mph trap speed at the end of the 1/4 with the pg7 over the PM6. if you were in hawaii i could prove it to you. there are some that say the PM6 is way better, but i was the judge of that.
Old Mar 19, 2004 | 09:16 AM
Default Re: (undefinedcrx)
Wow, thats a pretty good 1/4 mile run undefinedcrx. Are you using the Dx or the Si tranny?
Umbyman
Dec 8, 2009 06:33 PM
vdawg559
Nov 22, 2008 06:22 AM
turbodelsolb16a2
Jul 1, 2008 09:20 PM
Fezzie
May 10, 2006 11:59 AM
jrow87
17
May 19, 2004 05:25 AM
