Suspension removal (rear)
Old Mar 16, 2004 | 11:33 AM
CoolBreeze's Avatar
Default Suspension removal (rear)
Hi, I'm having trouble removing the struts from the rear of my '98 lude. All I took off was the main bolt holding it to the axle, but the strut is so long I can't get it off of the axle. What's getting caught is the end of the strut where it is C shaped.
Is there some other parts I need to removal also?
Thanks.
Old Mar 16, 2004 | 12:01 PM
OTT's Avatar
OTT
what do you mean by axle, Are you sure you dont meen the lower control arm?
Old Mar 16, 2004 | 12:17 PM
Honda Sport's Avatar
just push down on the whole rear assembly and pull it out.
Old Mar 16, 2004 | 12:48 PM
OTT's Avatar
OTT
and befor you start pushing down on the LCA and trailing arm make sure uve unbolted the mounting bolts at the top
Old Mar 16, 2004 | 01:12 PM
LudeyKrus's Avatar
It's not that hard; remove all bolts holding it all together, move everything out of the way that's in the way, and pull the struts out
Old Mar 16, 2004 | 09:30 PM
stupidfox's Avatar
Default Re: Suspension removal (CoolBreeze)
not sure if its the exact same but on my 95 i jumped up and down on it. seriously. and just in case you're installing energy suspension bushings- use a goddamn hydraulic press. took me two days to switch over one upper control arm mount. weak. good luck!
Old Mar 16, 2004 | 09:41 PM
BlAxNaIl's Avatar
just push the lower control arm down a little, and you can get it out.
it happened to me as well, was afraid i was gonna damage the whole thing.
but it turned out alright!!
Old Mar 17, 2004 | 01:41 PM
CoolBreeze's Avatar
Default Re: Suspension removal (BlAxNaIl)
I jumped on the brake assembly for 3 hours. At one point I had the strut off the lower control arm but then it was caught on some other things preventing me from sliding it out; like the upper wishbone and sway bar. My friend didn't want to take any major parts off cause he was afraid that we can't get them back on. Yes the 2 top bolts holding the strut was taken off. The strut is just so damn long!
So we end up spending another hour jumping on the brake trying to get the strut back on the arm to bolt back up. I knew it looked too simple at first.
LudeyKrus--what other parts did you take off?
Thanks.
Old Mar 17, 2004 | 07:02 PM
aschue's Avatar
Did you disengage the upper ball joint? Also make sure you jack up the whole rear of the car together. I initially made the mistake of jacking up one side of the car until I realized that the anti-sway bar was fighting me. Jack up the whole rear and it should come down easy. You still have to fish it out some but it comes out. Check out the write-up at http://www.ntpog.org/mods/fift...shtml. Rears are on the second page.
Old Mar 18, 2004 | 08:01 AM
CoolBreeze's Avatar
Default Re: Suspension removal (aschue)
aschue, thanks for the link. That explains everything. Yes, the car was on jack stands when I was working on it.
Thanks again.
ashtonallen
28
Nov 10, 2014 06:56 PM
Vagitarian
Feb 18, 2014 01:35 PM
bizak
May 30, 2011 07:33 AM
s13hero
Aug 18, 2009 11:23 PM
wayside
Jan 22, 2008 02:22 PM
