Changing struts
Old Jan 22, 2008 | 12:42 PM
wayside's Avatar
Default Changing struts
I'm running into a problem on the rear struts of my 2000 GS-R. The bolt connecting the control arm to the strut seems to be lodged. I've tried twisting, pulling, pushing, hammering, wd40, nothing seems to work, any ideas or suggestions?
Old Jan 22, 2008 | 12:54 PM
dc2_poojan's Avatar
Default Re: Changing struts (wayside)
jack up the lower control arm with your honda jack so it can be align and then get a skinny screw driver put in the hole den hammer it out
Old Jan 22, 2008 | 02:03 PM
Dogginator's Avatar
Daisy... Daisy...
The shock bolts connecting the rear shocks to the LCAs tend to seize inside of the bushings. Did these bolts unscrew? Most times the heads break off. If the heads did break off, you will need to cut the bolts and replace the control arm bushings. Most people use Energy Suspension polyurethane bushings for replacements.
If the bolts are loosened, you need to remove the two outer LCA bolts (one on each LCA) to allow for clearance.
Old Jan 22, 2008 | 02:22 PM
b18b1turboej's Avatar
If you are just doing springs and not the entire strut you can just remove the lca completly with the strut still attatched
93b20z
Mar 21, 2011 09:12 AM
streetracerjoey210
Jul 7, 2006 10:30 PM
b_serious
Oct 22, 2005 11:27 PM
OnePointFive
May 25, 2004 06:26 AM
stumpyf4
Aug 29, 2002 05:29 PM
