valve cover bolts on a d16z6
Old Oct 19, 2001 | 11:52 AM
max's Avatar
max
Default valve cover bolts on a d16z6
what are the exact sizes of the 2 long and 3 short bolts that hold the valve cover on a d16z6 engine? im tired of breaking them and i wanna get some steel ones from home depot or something
Old Oct 19, 2001 | 05:04 PM
rioninja's Avatar
Default Re: valve cover bolts on a d16z6 (max)
Bro, if you keep breaking them, that means your overtightening them. The nuts for the valve cover are designed to bottom out at a certain spot. Lots of people try to over tighten them so that the valve cover gasket will squash a little more and stop leaking. Once they get to a certain spot, thats it. They barely need to be tightened any more than a quick turn with a hand ratchet. If your valve cover leaks, just buy a new gasket.
DragII's Avatar
25 Year Member
Default Re: valve cover bolts on a d16z6 (RioNinja)
yeah man, they only take like 10 ftlbs....that's less than spark plugs
Old Oct 19, 2001 | 05:15 PM
max's Avatar
max
Default Re: valve cover bolts on a d16z6 (DragIIcivic)
no, see, i know how much i have to tighten them. i already went through breaking one this summer and i learned but i was adjusting my valves and i took my valve cover on and off several times. now the bolts feel weaker, and that's how i broke one of them. this is how i knew when to stop: when u tighten it, the little rubber thing under the head of the bolt will squish out, as soon as it does, i stop. but this time it didnt even squish at all! oh well, i guess i'll just go get a new one from honda...
Old Oct 19, 2001 | 05:21 PM
DragII's Avatar
25 Year Member
buy one from honda...get the rest elsewhere if they cost too much.
Old Oct 19, 2001 | 07:28 PM
KayOs's Avatar
Size is:
6 x 1.0mm torqued to 7lbs-ft
curtie94
Apr 2, 2011 03:46 PM
aystupet
Jun 30, 2010 05:00 PM
VtecCivic93
Jun 11, 2008 04:16 PM
Nicks95GSR
Jun 2, 2008 03:24 AM
matman4444
Aug 23, 2004 08:32 PM
