Quick yes no valve cover question
Old Aug 22, 2004 | 10:57 AM
matman4444's Avatar
Default Quick yes no valve cover question
We are about to paint my friends valve cover, after we take it off do we need to put a new valve cover gasket on? im guessing the gasket on there is just the stock d16 one. But i dont want it to leak oil and whatever..
Thanks
Old Aug 22, 2004 | 11:47 AM
LudeyKrus's Avatar
If you are careful pulling it off, it is not cracked or stretched, and is applied carefully again, you should be able to use it again no problem. Just make sure to use silicone sealant in the right places if you pull it off of the valve cover.
Old Aug 22, 2004 | 11:54 AM
red91sit's Avatar
Default Re: Quick yes no valve cover question (matman4444)
If it's still in good shape and squishy should be fine, also careful when you put it back on those bolts are weak! If it does leak you can try to fix it or get a new one and your only out about 5 minutes of time.
Old Aug 22, 2004 | 09:58 PM
matman4444's Avatar
Default Re: Quick yes no valve cover question (red91sit)
lol! i left, and when i came back he busted one of the bolts in there... i told him to be careful like you said but he thought he was the hulk..
Old Aug 23, 2004 | 07:59 AM
red91sit's Avatar
He he i thought they were my head bolts so i torqued them down to 43 lb/ft my first time
Old Aug 23, 2004 | 08:58 AM
Paprika's Avatar
Personally, I dunno how much these gaskets cost but if it's not too much I'd get a new one just to be on the safe side, and it will be one less thing to fail on you since it's new.
Old Aug 23, 2004 | 12:36 PM
vtec69's Avatar
you dont HAVE to as long as it isnt damaged
Old Aug 23, 2004 | 05:38 PM
matman4444's Avatar
be careful when tightening the bolts, my friend broke his second one like a dumbass when he was putting the vc back on after taking it off the get the other bolt off.... 6 bucks each bolt ouch
Old Aug 23, 2004 | 06:21 PM
LSVTEC 91 Civic's Avatar
Banned
Silicone is your friend.
Old Aug 23, 2004 | 08:32 PM
red91sit's Avatar
Default Re: Quick yes no valve cover question (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Silicone is your friend. </TD></TR></TABLE>
THat's EXACTLtyl what i keep telling my girlfriend
Menaco777
May 7, 2018 06:27 PM
optikal_blitz
Apr 21, 2003 01:44 PM
greddyturboGSR
Mar 24, 2003 05:19 PM
AnNiMosSiTY
Sep 1, 2002 09:34 AM
max
Oct 19, 2001 07:28 PM
