Eg wiring question
Heres the deal i bought a 94 Si and we just pulled the motor (b16) out of it. The car has a hydro tranny, axles, obd1 dizzy, and the shift linkage. MY question is can i buy an obd 0 motor and put the obd1 manifod and distrubitor with the obd1 engine wire harness on that obd 0 motor. Let me know what you suggest. And yes i searched for the obd0-obd1 conversoin and they were taling about doin it backwards or something.
you going to have to use the injectors that match the dizzy. but it will work only difference between obd motors are the sensors on them for the restrictions. besides that same thing.
an obd0 engine will work. you will need your dizzy, and the injectors, or the obd0 injectors with clips and resistor box. i have never done a manifold switch, on the obd0-1 but i did an obd0 ls manifold on a b20 so i am assuming it will switch over on your b16's.
Sleepy_Red_hatch
Mar 4, 2006 08:59 AM
KevronsEG
Nov 7, 2002 09:25 AM
