Question?
Old Mar 15, 2004 | 04:30 PM
Rob1186's Avatar
Default Question?
What does a wastegate and blow off valve do?
Do you need an intercooler to have a turbo?
Old Mar 15, 2004 | 05:07 PM
blah13's Avatar
Default Re: Question? (Rob1186)
Wategate - allows exhaust gas to bypass the turbine to regulate boost levels.
BOV - releases pressure when throttle is shut to prevent air from running back into the turbo and causing a violent reaction
and no you dont have to have an intrercooler but it cerainly helps, mainly to help reduce detonation by lowering intake temps...which then also adds power due to increased air density.
Old Mar 15, 2004 | 05:32 PM
Kamin's Avatar
Default Re: Question? (blah13)
when you dont run a BOV on a turbo, its called compressor surge. if you have been around them long enough you can hear it when someone hasnt adjusted their BOV well enough.
and an intercooler isnt 100% necessary to most people but it is to me. the air is super heated by the turbo and hot air = less horsepower and more of a chance for detonation. detonation can blow your engine.
Old Mar 15, 2004 | 07:03 PM
doublejz's Avatar
Default Re: Question? (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">when you dont run a BOV on a turbo, its called compressor surge. if you have been around them long enough you can hear it when someone hasnt adjusted their BOV well enough.
and an intercooler isnt 100% necessary to most people but it is to me. the air is super heated by the turbo and hot air = less horsepower and more of a chance for detonation. detonation can blow your engine.</TD></TR></TABLE>
Well said
booscivic
Mar 28, 2005 11:29 AM
BigPlansNoMoney
Jan 20, 2005 08:00 AM
PetroGuyX
May 2, 2003 07:35 PM
GettaluvR
Oct 3, 2002 09:22 PM
ion_four
Jun 14, 2002 04:25 AM
