Q ABOUT WELDING A Manifold
Old Mar 15, 2004 | 03:10 PM
RACEPAK's Avatar
Default Q ABOUT WELDING AN exhaust Manifold
HEY EVERYBODY
I LEARND IN HIGH SCHOOL HOW TO WELD .
CAN I DO TURBO A Manifold BY MYSELF??
DOSE ANYBODY KNOWS THE MASURES FOR AN EURO 94 Esi HATCHBACK 1.6L
Manifold?
IN MY COUNTRY ITS HARD TO GET THESE PARTS . (I'M FROM ISRAEL)
THANKS ALOT GUYS
M.G.
Old Mar 15, 2004 | 03:14 PM
Ricey McRicerton's Avatar
Default Re: Q ABOUT WELDING A Manifold (RACEPAK)
If you have the confidence in yourself I say go for it. You'll need a plate that mounts to the head, and some tubing and get to work. You'll need a adapter plate for the turbo to mount to as well.
Good luck!
BTW: I learned to weld in HS too and it's a great skill to know!
Old Mar 15, 2004 | 03:17 PM
RACEPAK's Avatar
Default Re: Q ABOUT WELDING A Manifold (Ricey McRicerton)
I THINK I'M GONNA DO IT.
I CAN TAKE THE HEAD PLATES FROM THE STOCK EXHAUST? OR BIGGER ONE'S??
BUT I NEED THE MASURES OF THE MANIFOLD LANGHT FROM THE BEGINING OF THE PLATES TO THE adapter plate oF the turbo
(OR CAN DESIDE THE LANGTH??) I WANT ABOUT 1.0 BAR BOOST. IS IT POSIBLE TO DO IT BY MT SELF ??
AND I ALSO NEED A FLANGE FOR THE BOV.
Old Mar 15, 2004 | 03:31 PM
lohatch's Avatar
you can usually buy the flanges to bolt to the head on ebay as well as a flange for various turbos depending on what you want to use. also the bov goes on the charge piping not the manifold. the wastegate goes on the manifold. also your turbo might come with an internal wastegate meaning you wouldnt need to make a flange for an external one. you will probably want to make something simular to these ones. good luck
Old Mar 15, 2004 | 03:43 PM
hybridzOr's Avatar
Default Re: Q ABOUT WELDING A Manifold (lohatch)
mod an hf manifold
and stop yelling plz..
make sure you get acouple of flanges as you WILL mess up..
Old Mar 15, 2004 | 03:48 PM
Millenion LTD.'s Avatar
California,The only state
Default Re: Q ABOUT WELDING A Manifold (Hybrid Racer)
one more post for today, dont waste it
just keep going back to "Edit" your posts haha
Old Mar 15, 2004 | 04:01 PM
h22avid's Avatar
Yeah, get plenty of flanges.
I'm not so sure this would be the best DIY for the inexperienced. I respect your gusto but there's a lot more to making a manifold then simply welding some tubes together.
I'm sure you could weld something up but how will it flow and how will it end up performing on a dyno? I would save this task for the pros who have engineering and automotive experience.
Just my .02.... if you think you can build a decent manifold then by all means go for it because you will save a ton of cash.
Old Mar 15, 2004 | 04:49 PM
lohatch's Avatar
Default Re: Q ABOUT WELDING A Manifold (h22avid)
i am also with the guy above about the task of making a manifold. there is a little more involved here but if you think you can do it then go for it. i would suggest using 314 stainless instead of 304 as it stands up to the heat better.
Old Mar 16, 2004 | 04:20 AM
RACEPAK's Avatar
Default Re: Q ABOUT WELDING AN exhaust Manifold
maby i'll just buy one from e-bay
is it any good?
http://cgi.ebay.com/ebaymotors...34177
i'll send it to chrome plating after i'll get it.
can i make a downpipe by myself??
Old Mar 16, 2004 | 04:24 AM
Ej94EX
Guest
Posts: n/a
Default Re: Q ABOUT WELDING AN exhaust Manifold (RACEPAK)
^^^ just got owned by the 5 post rule.... Thats why i made a sn let it sit for 10 days...and now im a member again wooT!
Teglove2
Welding / Fabrication
13
Jan 25, 2010 06:03 PM
turbotime
Apr 30, 2007 12:51 AM
wpgcivic
May 7, 2006 07:26 AM
TeamDOHCside
Jul 2, 2003 11:19 AM
