OBD2 Motor, OBD1 Car and Harness
Old Mar 15, 2004 | 05:24 AM
superfuji57's Avatar
Default OBD2 Motor, OBD1 Car and Harness
Ok, I have a '94 GSR shell, I'm trying to use the '94 engine harness on a newer '98 GSR motor. I changed out the injectors, distributor, and alternator, but it appears that I have left over plugs....like 3 actually. One of the sensors won't plug up, one that goes right under the 2nd runner on the IM. Can anyone help? TIA
Old Mar 15, 2004 | 09:11 AM
IN VTEC's Avatar
Default Re: OBD2 Motor, OBD1 Car and Harness (superfuji57)
List the wire colors on the plugs in question so somebody can look them up on a diagram and give you the correct sensor or actuator that it plugs into.
I know you won't need to plug in the CKF sensor on the oil pump, but I can't think what the other two might be.
Old Mar 15, 2004 | 12:05 PM
You mean that plug will be left over from the harness? And it won't throw code? I'll have to wait til I get off work before I can look again. Thanks
Old Mar 15, 2004 | 01:26 PM
FastSS's Avatar
Default Re: (superfuji57)
It depends on whether you're gonna use an OBD-1 or OBD-2 ECU. Since you already swapped to using the OBD-1 injectors, distributor, alternator, and wiring harness, you should be using an OBD-1 ECU....which won't look for a CKF input sensor.
Ben
Old Mar 15, 2004 | 02:23 PM
Default Re: (FastSS)
Yeah, I'm using an OBD1 ECU. Right now, the only code I'm throwing is o2 sensor I think, and that's because I forgot to unplug it when I pulled the motor out so all the wires came off the plug Anyways, thanks Ill check up on it again later.
TravisBiggie
May 24, 2012 07:13 AM
Cuda
Jan 16, 2008 06:18 AM
Jabinya
Jul 16, 2007 04:33 PM
cthan3o3
13
Jul 31, 2005 08:27 AM
TURBOED-TEG
Sep 14, 2002 02:28 PM
