crx b18c knock sensor Question
Old Mar 14, 2004 | 02:57 PM
b18crxjrsc's Avatar
Default crx b18c knock sensor Question
i have a crx with a b18c running b16a1 ecu and the knock sensor is broken,would this be a power loss if it is not plugged in ?
Old Mar 14, 2004 | 04:40 PM
Cory man's Avatar
Default Re: crx b18c knock sensor Question (b18crxjrsc)
Why is this a poll?
Old Mar 14, 2004 | 05:00 PM
HamiltonRex's Avatar
Hook up your knock!
Dont be stupid
Its a 1 wire sensor located on the rear of the engine, you can get to it by laying under your car and just reaching like a *****.
-Eric
Old Mar 14, 2004 | 05:02 PM
Fobtions's Avatar
Default Re: crx b18c knock sensor Question (HamiltonRex)
wire that **** in, u are losing power.
Old Mar 14, 2004 | 05:52 PM
jedubz's Avatar
Default Re: crx b18c knock sensor Question (Fobtions)
Why would you lose power by throwing code 23? I'm so in the dark here....
Old Mar 14, 2004 | 07:32 PM
sikcrx80's Avatar
yeah it wont work very well... ur botom end might be stronger till u hit vtec then it will throw a code then power will fall off...
could alway put single vtec puter in and get it chiped then u dont need knock..
just my 2 cents
Old Mar 14, 2004 | 10:21 PM
Fobtions's Avatar
Default Re: crx b18c knock sensor Question (jedubz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jedubz &raquo;</TD></TR><TR><TD CLASS="quote">Why would you lose power by throwing code 23? I'm so in the dark here.... </TD></TR></TABLE>
since your ecu is "in the dark" on to whats going on with the combustion process and not know ing it might be knocking or not. it takes timing away and makes it run so it will get you home.
Old Mar 23, 2004 | 12:47 PM
b18crx's Avatar
where is the wire? i have an 88 crx with an itr motor. my harness does not have the plug but the motor has the sensor, should i get a J&S safeguard? if so, which one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">Hook up your knock!
Dont be stupid
-Eric</TD></TR></TABLE>
baulum
Aug 16, 2007 09:22 AM
acclude-vtec
Jan 2, 2006 11:00 AM
LaosIntegra
Apr 18, 2005 09:33 PM
CRexcellence
Apr 29, 2003 09:05 AM
jonas
Aug 25, 2002 04:46 PM
