Extremely high idle problem
Old Mar 13, 2004 | 09:07 AM
billybong91DA's Avatar
Default Extremely high idle problem
I have a 91 teg, and when i start it up any time of day, whether it has been running for while or not, and it starts to idle at around 2800-3000 rpm, it only goes down to about 22 and stays there, what could be wrong? could it be a bad TPS or IAC valve?
Old Mar 13, 2004 | 10:03 AM
swanny's Avatar
Default Re: Extremely high idle problem (billybong91DA)
Take out and clean your IACV
Old Mar 13, 2004 | 01:00 PM
Yambor's Avatar
Default Re: Extremely high idle problem (xy swany)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xy swany &raquo;</TD></TR><TR><TD CLASS="quote">Take out and clean your IACV </TD></TR></TABLE>
ill second that...if you dont know how im sure there are threads on here about that..
also check for vacuum leaks..
Old Mar 14, 2004 | 01:12 PM
theman1004's Avatar
my integra had the same problem. i had to replace the tps sensor.
go2sleep
Jun 15, 2006 08:54 PM
90AcuraIntegra04
Dec 11, 2005 05:26 PM
Shmolie
Jun 29, 2005 05:58 PM
TheIntegraGuy
Jan 22, 2004 06:48 PM
quik2kSi
Dec 27, 2003 09:04 AM
