GSR compressor/bracket in a swapped 95 coupe?
Hello....I have a quick question for you guys
Ok...I have a 95 civic coupe with a jdm b16 in it
I was going to go with the dohc del sol vtec a/c bracket to get a/c to work with my swap...its hard to find as you know....
So someone told me that I can go with a gsr compressor and a/c bracket...and just get my a/c lines widened to work with them?
what do you think? will this work ok? I do not want to buy them until I know it will work ok
Has nothing to do with A/C lines. It has to do with the 4 bolts that connect your Civic A/C compressor to the block. With anything other than a Del Sol DOHC VTEC A/C bracket not all 4 bolts will line up and you will end up snapping some most likely.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King Tut33 »</TD></TR><TR><TD CLASS="quote"> With anything other than a Del Sol DOHC VTEC A/C bracket not all 4 bolts will line up and you will end up snapping some most likely.</TD></TR></TABLE>
100% true i know from experience, i snapped 2 bolts off, my compressor was basically hanging there till i splurged for the p54
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civeg »</TD></TR><TR><TD CLASS="quote">100% true i know from experience, i snapped 2 bolts off, my compressor was basically hanging there till i splurged for the p54
Same here with a '99 Si bracket. I broke one of two bolts holding it on. I then spent the money on a P54.
</TD></TR></TABLE>Same here with a '99 Si bracket. I broke one of two bolts holding it on. I then spent the money on a P54.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King Tut33 »</TD></TR><TR><TD CLASS="quote">Tell them 1995 Honda Del Sol DOHC VTEC P54 A/C Bracket.</TD></TR></TABLE>
verbatim
verbatim
stehigs321
Jul 10, 2003 01:24 PM
