OMG HELP. GSR Motor in EK, what A/C bracket
Hey i recently did a motor swap of a B18c1 into my 96 EK coupe. I took out the A/C condensor and compressor because the condensor had a leak. Im finally getting around to getting put back in and it is sitting at my local honda right now. I need to know ASAP what A/C compressor bracket i need to have them order. Del sol or Si. And do i just need the bracket? or are there any other parts related to the bracket that i might need? which bolts?
thank you guys so much.
stehigs321@aol.com
stehigs321@aol.com
Re: OMG HELP. GSR Motor in EK, what A/C bracket (slowdx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowdx »</TD></TR><TR><TD CLASS="quote">im pretty sure its the del sol vtec bracket p54...
You can use the stock bolts for the bracket </TD></TR></TABLE>
Del Sol VTEC bracket is the one.
If you still have the b-series ac comp and the bracket, you can use that. Just buy the thicker ac hose from a 99si. its alot cheaper and easier to find then looking for a p54 bracket.
t_dot_SiR
07-01-2006 09:23 AM
CTL
19
05-05-2004 01:57 PM
