compression test results (need help)
Old Mar 11, 2004 | 09:46 PM
desert eagle's Avatar
Default compression test results (need help) problem fixxed thanks guys
all these #s are wack it was the comp. tester
#1 170
#2 160
#3 150
#4 190
why are they so inconsistant? they look hella low too.
set up: b20vtec 11.3:1 cr jun 3.
headgasket? valves? sleeves? help please. doing a leak down test tomorrow.
Modified by B20vtec81 at 9:31 PM 3/12/2004
Old Mar 11, 2004 | 09:49 PM
Kendall's Avatar
Being that they are at the lower point between cylinders 2 and 3, I wouldn't rule out the possibility of a headgasket leak between the two. I would otherwise tell you to invest in a new set of rings. I believe it's time for a good rebuild.
Old Mar 11, 2004 | 10:27 PM
Default Re: (Kendall)
only 1500 miles on rebuild but had to replace 4 exh valves because the cam broke. and i reused the headgasket.
Old Mar 11, 2004 | 11:12 PM
slixxracing's Avatar
Default Re: (B20vtec81)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20vtec81 &raquo;</TD></TR><TR><TD CLASS="quote">and i reused the headgasket.</TD></TR></TABLE>
Thats a no no...Never use an old head gasket. From personal experiece. Spend an extra 60-70 bucks to get a new one.
Old Mar 11, 2004 | 11:44 PM
r2ck_p's Avatar
Default Re: (slixxracing)
Yeah I recently had my B16B rebuilt, was told always to get a new head gasket. Did a compression test it’s was around 250 each, is this about right??
Old Mar 12, 2004 | 12:26 AM
RangerJoe's Avatar
a new headgasket is so cheap anyway, so why not just get a new one if you are rebuilding the engine.
Old Mar 12, 2004 | 02:17 AM
Default Re: (RangerJoe)
i did get a new one but my jun3 cam (exh) snapped 76 miles into break-in and bent 4 exh valves so i i was already peaked over my budget and didnt think 76 on a headgasket would harm anything.
so i think its between the HG and valveseats where my 4 valve bent. but when i replaced the valves the seats looked in mint condition. but they didn't get checked
Modified by B20vtec81 at 8:17 AM 3/12/2004
Old Mar 12, 2004 | 07:17 AM
any more help fellas?
Old Mar 12, 2004 | 07:23 AM
powerofdreams8's Avatar
Just be careful what you do from this point, you may end up wasting alot of time.
My friend had a very similar situation. Poor compression in a b20vtec; adding oil to the suspect cylinder brought the comp numbers way up so we thought it was the rings. Replaced the rings only to find out the compression numbers were all exactly the same. The b16 that the head came from had 2 bent exhaust valves whcih we replaced ( seats looked mint just like you said). So now we suspect it must be those valves.
Old Mar 12, 2004 | 07:31 AM
Default Re: (powerofdreams8)
good info bro
Old Mar 12, 2004 | 09:32 AM
crxsirvtec's Avatar
I reused my headgasket after 10 to 15 miles...
after about 20,000 miles later.. lots of 9000 rpm shifting my b16 is 200 to 205 across all 4 cyl..
did you have the throttle 100% open?
crank like 4 to 5 times?
fully charge good battery?
Old Mar 12, 2004 | 08:29 PM
Default Re: (crxsirvtec)
yeah i used a guage that wasn't all outta wack and it read 225 1-3 230 on #4. engine has 1550 miles on it.
turbosivtec
May 24, 2009 04:33 PM
jdmek2277
11
Sep 9, 2008 07:44 PM
pos_cd5
19
May 6, 2006 03:21 PM
2fast4u831
17
Aug 29, 2004 02:29 AM
lsvtec42
Dec 6, 2001 12:39 PM
