Crank Angle Sensor HELP please
Old Mar 10, 2004 | 02:32 PM
4DRPIMPIN's Avatar
Default Crank Angle Sensor HELP please
I am trying to add a crank angle sensor on a obd 2 ITR motor. The motor does not have a spot for it. What will happen if I don't hook it up? Please advise. It is going in a 96 civic obd2. thanks in advance...
Old Mar 10, 2004 | 03:00 PM
Kataku2K3's Avatar
Default Re: Crank Angle Sensor HELP please (4DRPIMPIN)
Is this a JDM motor? You're actually refering to the crankshaft speed fluctuation sensor (CKFS) on the oil pump, correct? If that's the case and you have a JDM motor lacking the CKFS mounting points you'll need to get yourself a '96+ USDM GSR/ITR oil pump. Then all you'll need is the CKFS pulley and the sensor itself.
Old Mar 10, 2004 | 03:11 PM
4DRPIMPIN's Avatar
Default Re: Crank Angle Sensor HELP please (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">Is this a JDM motor? You're actually refering to the crankshaft speed fluctuation sensor (CKFS) on the oil pump, correct? If that's the case and you have a JDM motor lacking the CKFS mounting points you'll need to get yourself a '96+ USDM GSR/ITR oil pump. Then all you'll need is the CKFS pulley and the sensor itself. </TD></TR></TABLE>
Really, yeah it is a JDM motor. Is there any way of mounting it with out the gsr/itr oil pump?
Old Mar 10, 2004 | 03:15 PM
Kataku2K3's Avatar
Nope, you need an OBDII oil pump.
Old Mar 10, 2004 | 03:39 PM
4DRPIMPIN's Avatar
What will happen if I didn't hook it up with the obd2 ecu? Or if I ran a obd 1 computer?
Old Mar 10, 2004 | 03:51 PM
HamiltonRex's Avatar
get a conversion harness and run a ecu, just hook up everything else but that sensor that isnt there because there is no obd2 in JDM land.
-Eric
Old Mar 10, 2004 | 04:36 PM
Kataku2K3's Avatar
Default Re: Crank Angle Sensor HELP please (HamiltonRex)
It's not going to run too well if you just don't wire it up. But yes, that is the other option, get a OBDI P72 (I personally would go with a chipped P28 even tho it doesn't have IAB control just because I hate the stock GSR ECU0 and OBDIIa-OBDI jumper. The easiest thing to do would just be to find a '96-99 JDM ITR P73 ECU as it's straight plug and play and actually is an OBDI ECU (doesn't look for VTM, CKFS, or a secondary oxygen sensor). Get yourself a CTR or ITR IN cam, a SK2 IN manifold and you won't even have to worry about the IAB's. Or just pull and cap the vacuum line running the to IAB diaphram (it won't let them be sucked closed while your motor is running).
Old Mar 10, 2004 | 05:54 PM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">It's not going to run too well if you just don't wire it up. But yes, that is the other option, get a OBDI P72 (I personally would go with a chipped P28 even tho it doesn't have IAB control just because I hate the stock GSR ECU0 and OBDIIa-OBDI jumper. The easiest thing to do would just be to find a '96-99 JDM ITR P73 ECU as it's straight plug and play and actually is an OBDI ECU (doesn't look for VTM, CKFS, or a secondary oxygen sensor). Get yourself a CTR or ITR IN cam, a SK2 IN manifold and you won't even have to worry about the IAB's. Or just pull and cap the vacuum line running the to IAB diaphram (it won't let them be sucked closed while your motor is running). </TD></TR></TABLE>
actually it doesn't run all that bad, i've worked on a EK with a obd1 b18c1, and a obd2 gsr ecu, and it ran fine, just threw a check light for it.
Old Mar 10, 2004 | 05:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">The easiest thing to do would just be to find a '96-99 JDM ITR P73 ECU as it's straight plug and play and actually is an OBDI ECU (doesn't look for VTM, CKFS, or a secondary oxygen sensor). </TD></TR></TABLE>
That completely slipped my mind
Yeah the JDM ecu is the best way to go.
-Eric
Old Mar 10, 2004 | 06:01 PM
Kataku2K3's Avatar
Default Re: Crank Angle Sensor HELP please (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">actually it doesn't run all that bad, i've worked on a EK with a obd1 b18c1, and a obd2 gsr ecu, and it ran fine, just threw a check light for it.</TD></TR></TABLE>
I have too, even though the CKFS reference is mainly used to detect misfires, etc. cars that I've worked on still ran better overall after the sensor is wired back up. Who wants to look at a CEL either?
Old Mar 10, 2004 | 07:19 PM
4DRPIMPIN's Avatar
thanks for the info, I'm Probably gonna run a chipped obd1 p28. Just trying to get through one problem at a time... Thanks again.
Old Mar 10, 2004 | 08:45 PM
thad
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">get a conversion harness and run a ecu, just hook up everything else but that sensor that isnt there because there is no obd2 in JDM land.
-Eric</TD></TR></TABLE>alota work and money when you could probably snag that pump for about 50 bucks
Old Mar 10, 2004 | 09:05 PM
Kataku2K3's Avatar
Default Re: Crank Angle Sensor HELP please (thad)
My friend got a '98 JDM ITR ECU from a guy in Malaysia for $120.00 + $8.00 for shipping. Wasn't a bad deal at all and it made all the difference on his setup (B18C1/EJ6, CTR IN cam, and SK2 IN manifold, so you can see why).
Old Apr 23, 2004 | 12:04 PM
dremmel's Avatar
damnit if i don't have the same problem . My D15B vtec in a '92 VX w:z6 harness and P28 ecu 5spd. It had trouble starting like the day b4 it wouldnt crank over. This is a CODE 24 right? Some1 said it's by the dizzy, so i swapped my dizzy and it still has same prob. Where the hell is the CRANK ANGLE SENSOR on a D15B vtec? hellllp, not hijacking... same issue
Old Apr 23, 2004 | 12:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thad &raquo;</TD></TR><TR><TD CLASS="quote">alota work and money when you could probably snag that pump for about 50 bucks</TD></TR></TABLE>
work?
Plug the harness in.
Plug the Ecu in.
-Eric
Old Apr 23, 2004 | 05:46 PM
3rdGteg's Avatar
work?
Plug the Ecu in.
-Eric</TD></TR></TABLE>That's what I was thinking
Changing the oil pump is way more work than that, especially with the motor already in the vehicle....trust me I know, just did one a couple of days ago.....btw, you'll need the obd2 lower timing cover also (including what Kataku2K3 listed above) & the oil pump is around $100, not 50 bucks.
CW-ITR
Nov 19, 2012 06:14 PM
tnxx
Dec 7, 2009 05:43 PM
H2BSTUPID
Mar 20, 2009 06:41 PM
who00knows
Mar 18, 2004 07:56 AM
