Rear-disc conversion on 92EG/DX questions.
Will 94-96 integra LS trailing arms etc. work for my car? What all do I need above and beyond necessary hardware? Also, should I rotors/calipers for the front as well?
Peace!
Peace!
yes you can drop out the entire rear arm and it will bolt up to your car. I did the same. I removed the whole rear brake assembly and bolted it right up to my car. Make sure you get the e brake cables. Also you may want to look into the integra rs master cylnder it is 15/16ths non abs, prop valve and booster. I do not have these parts yet. I would at least get the master cylinder. HTH
Thanks Hybrid-T:
is their anything you would recommend additional to the swap I may need besides the RS master cylinder? What about tricks, do all the parts have the potential of comming off the teg and bolting to my EG without problems? Just mere curiosity!
im actually junkyard hopping now looking for brake parts as well. yes, the parts will bolt right up. just make sure you get all the brake lines, ebrake lines, and just try to figure out the condition of the car, ie. milage, damage, etc.
yeah definitely get the brake hose if your trailing arms didn't already come with them, the rear trailing arms i got had everything besides the brake hose. the stock brake hose you have (drums) won't fit correctly, fluid will leak out.
wow, next time you have a question there is a cool thread up at the top of this forum its called FAQ READ IT!!!!!!!!!!!!!!!!!!!
https://honda-tech.com/zerothread?id=152884
Weeding through that FAQ is hell, especially when you want a quick answer. Further more, alot of the info added (not the post originator) is misleading and frankly BS, so *blow me* NORCAL you're a jack ***!
L8
L8
fryman
Aug 7, 2015 06:49 PM
cehcivic15
Aug 10, 2012 03:20 PM
949
31
Oct 7, 2009 11:17 PM
95DXPhiladeph
Apr 6, 2004 08:21 AM
