will these brake parts interchange to eg(ej2) from em1
im needing a new brake booster on my 95 dx coupe. my friend has a 99si that is going to the scrap yard soon and is willing to give me parts off of it that i might need. the car is an hour away, so i was wanting to make sure the brake booster would work on my car before we made the trip. i went through the faq, and searched for this info with no luck. i checked out the oem part numbers and they are different, but thats not to say they wont interchange and work. if i need other parts for it to work right, i can get the prop valve, master cylinder, and calipers,rotors and so forth, as well as the rear setup. however, the only thing i NEED is the booster
Re: will these brake parts interchange to eg(ej2) from em1
it should work... the civic si has slightly larger brakes than your dx (10.3in vs 9.5in), but i believe the brake booster is the same. would be a little bigger if you went to an integra booster... read up on this thread:
https://honda-tech.com/forums/showth...ht=brakeexpert
lots of good info on that thread
guitarhero728
10-03-2013 08:25 AM
DO/\/\O
20
09-10-2011 08:22 PM
P2TOY
07-16-2006 02:02 PM
