Nitrous and Duration, I need a real answer
Old Mar 9, 2004 | 08:55 PM
RTE117's Avatar
Default Nitrous and Duration, I need a real answer
I've searched and found numerous threads of the debate about nitrous with big cams. I need to really know if the theory that applies to boost is the same for spray. I wanna gets cams and I'm deciding between N/A stage I or II's or special high lift short duration cams (turbo cams). I realize overlap can be played with using cam gears, but I need a definitive answer so I know if duration weakens the shot by letting it all 'slip' out the exhaust valve. TIA
BlackRocket
Dec 21, 2004 06:37 PM
6thgen_H22accord
Mar 1, 2004 01:08 PM
BolivianDc2
Aug 24, 2003 08:10 AM
