LSVtec Q's (searched)
Old Mar 6, 2004 | 02:47 AM
grey16's Avatar
Default LSVtec Q's (searched)
I am getting ready to turn my LS-T into LSVTEC turbo. What kind of headgasket should I use will OEM be good or should I get a thicker headgasket if so what brand and were can I get them. Also the guy I am getting the head (b16a) off of has GSR cams should I use them or will there be problems with the lift with these cams. Has anyone used blocksgaurds on LSvtec motors which ones work great and which ones suck a$$. Thanks for the help any other info would be great.
Old Mar 6, 2004 | 03:22 AM
dr_latino999's Avatar
Default Re: LSVtec Q's (grey16)
Well first, what do you want your compression ratio to be? Second, there is a great write up on the LS/Vtec and all the parts you will need over at http://www.hondaswap.com/forum...&t=11, this should tell you which parts to use from what.
Old Mar 7, 2004 | 06:11 PM
jdm91integ's Avatar
Bump
Old Mar 9, 2004 | 09:02 PM
Rod.'s Avatar
Default Re: LSVtec Q's (jdm91integ)
I would use the gsr cams in your b16 head. The gsr cams do wonders on boost. Block guards are ok ,but i prefer sleeving.
Jdm_Ej8_Sedan
Feb 25, 2014 05:04 PM
MrMug3n
Apr 8, 2009 06:36 AM
dohdoh420
Feb 13, 2007 11:30 AM
SleepinTeg
May 31, 2006 06:44 PM
Dorikamu
Mar 2, 2003 01:14 AM
