CTR SRS steering wheel problem....
Old Mar 9, 2004 | 07:49 PM
the_illest_soldier's Avatar
Default CTR SRS steering wheel problem....
...I just installed my steering wheel and now the horn doesnt work. I hooked the wire up to the connector for the horn and now all i hear is a click from under the dash near the fuse box. Im thinking that maybe i blew a fuse or something but i havent checked yet. Is there anything else that could be wrong?
Old Mar 9, 2004 | 07:56 PM
Built Beast's Avatar
Default Re: CTR SRS steering wheel problem.... (EKcoupe99)
just check the horn fuse, that is probably your problem.
Old Mar 9, 2004 | 08:52 PM
BlueIntegraBoy's Avatar
Default Re: CTR SRS steering wheel problem.... (R33CIVIC)
Isn't the horn fuse the same as your brake light fuse? Umm, better make sure your brakes work.
Old Mar 10, 2004 | 09:03 PM
Default Re: CTR SRS steering wheel problem.... (BlueIntegraBoy)
horn fuse is still good. Any suggestions?
Old Mar 10, 2004 | 09:27 PM
veggiemaster's Avatar
did you flip the wires?
Old Mar 10, 2004 | 09:52 PM
Default Re: CTR SRS steering wheel problem.... (veggiemaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veggiemaster &raquo;</TD></TR><TR><TD CLASS="quote">did you flip the wires?</TD></TR></TABLE>
No....the wires both connected to make on wire. Then i just clipped that wire into where the original horn wire was.
Old Mar 10, 2004 | 10:00 PM
you make sure the horn is plugged up, just pop the hood and it is below the Rad support. you can get it off easy, then just take the two wires and touch them to your battery to see if it is the horn or the wiring somewhere else. you horn may have taken a **** on you.
Old Mar 10, 2004 | 11:20 PM
kidkombo's Avatar
u broke you your cable reel... i did the same to mine
Old Mar 11, 2004 | 08:37 AM
Default Re: CTR SRS steering wheel problem.... (kidkombo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidkombo &raquo;</TD></TR><TR><TD CLASS="quote">u broke you your cable reel... i did the same to mine</TD></TR></TABLE>
Can you explain some more?
Thanks for the help
Old Mar 11, 2004 | 04:58 PM
bump
Old Mar 11, 2004 | 05:27 PM
Your cable reel is a disc thingy behind your steering wheel. It rotates when you turn the wheel. Coming from the cable reel are wires for your SRS, horn, and cruise plugs. The group of wires connect to your cable reel via a plug held on by tape. To me, it looks like the plug is not held in very good.
What kind of steering wheel did you put in? I heard the JDM wheels have a horn problem with the USDM cars. I think you need to rig it somehow.
Old Mar 11, 2004 | 09:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Your cable reel is a disc thingy behind your steering wheel. It rotates when you turn the wheel. Coming from the cable reel are wires for your SRS, horn, and cruise plugs. The group of wires connect to your cable reel via a plug held on by tape. To me, it looks like the plug is not held in very good.
What kind of steering wheel did you put in? I heard the JDM wheels have a horn problem with the USDM cars. I think you need to rig it somehow.</TD></TR></TABLE>
Thanks for the info. I put in a CTR SRS wheel
llteddy4playll
Aug 17, 2007 01:54 PM
lsracer27
Jan 28, 2007 11:33 AM
BlueIntegraBoy
Oct 20, 2006 05:38 PM
XxSOHCDriVerxX
Oct 1, 2003 06:24 AM
rattletrap
Jul 13, 2003 07:46 PM
