boost gauge/air fuel gauge wiring...???
Old Mar 9, 2004 | 07:14 PM
91tegrals's Avatar
Default boost gauge/air fuel gauge wiring...???
were do i hook into for the power i have a ground and power for the boost and the same for the a/f gauge so were do i get the power from and on a single wire o2 do i just splice into that one wire for the gauge..and i did search and it helped a little but just wanted to make sure i had my **** straight before i **** somthing up....
Old Mar 9, 2004 | 07:45 PM
TABIAS's Avatar
I want to be MADE into Ice-T
Default Re: boost gauge/air fuel gauge wiring...??? (91tegrals)
for the boost gauge for power you run a wire to your fuse box and i taped into the instrument pannel/light fuse
that's just what i did good luck
edit: if the a/f gauge all you need to do it splice into the white wire on the o2 and ground it off, that should do it
good luck
Old Mar 9, 2004 | 08:25 PM
dunkd's Avatar
yup i just did both mine yesterday
if u have obd1 ecu the o2 sensor at the ecu is D14, its the only white wire on the D plug. The D plug is the 3rd one, it is the medium size.
Old Mar 10, 2004 | 06:49 AM
91tegrals's Avatar
well i have a obd0 so its only one wire so do i just tap that one and thanks about the boost gauge info ill probley try and do that thanks...
nicko360
Mar 7, 2007 03:20 PM
Multra Corakus
Apr 21, 2006 09:00 PM
IntegraMastaz
Apr 6, 2006 10:06 AM
SuperpooV
Dec 3, 2003 05:05 PM
braintree
Jul 16, 2003 12:20 AM
