Compression test - 220 across the board... good?
Old Mar 9, 2004 | 06:38 PM
top fuel's Avatar
Default compression test?
well i visited california this weekend and had to fly back but there is a deposit on the car and the seller went to go get it inspected for me and he told me that everything was fine, but the horn was disconnected because of the jdm conversion? (thats what he was saying) if this IS true could i able to connect it back?
he also said that they did a compression test and it read 220 220 220 220 is that about right on a stock itr?
edit: i also will be receiving the fax tomrrow
Old Mar 9, 2004 | 06:40 PM
itr 00 0108's Avatar
Default Re: compression test? (top fuel)
Seems low to me but your numbers are very very consistent which is good.
Kendall's Avatar
220 across the board is good. I wouldn't worry at all. And yes you can reinstall the horn with the JDM front.
Old Mar 9, 2004 | 06:58 PM
B2FiNiTY's Avatar
As long as the numbers are consistent like yours, they are fine.
Old Mar 9, 2004 | 07:36 PM
Nameless RB26's Avatar
Default Re: compression test? (B2FiNiTY)
100% fine. Low numbers mean jack **** when it's even like that.. unless it's 0 across.
Old Mar 9, 2004 | 09:11 PM
top fuel's Avatar
thanks
Old Mar 9, 2004 | 09:27 PM
uNF$@#!'s Avatar
Default Re: compression test? (Nameless RB26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless RB26 &raquo;</TD></TR><TR><TD CLASS="quote">100% fine. Low numbers mean jack **** when it's even like that.. unless it's 0 across.</TD></TR></TABLE>
...unless you screw up all 4 cylinders
Old Mar 9, 2004 | 09:35 PM
Bbasso's Avatar
Looks like a normal motor, even tho I had 230-235 across all four
Old Mar 9, 2004 | 09:38 PM
Kendall's Avatar
It could very well be miscalibrated testing equipment (a tester that got "knocked out of whack" as we say it around here).
Old Mar 9, 2004 | 11:31 PM
TheGSRGuy's Avatar
Default Re: (Grizzly Adams)
220 all the way across? Damn, that's like right on the factory spec.
But that's Honda for you, "consistent as water"....as my local shop said.
Old Mar 10, 2004 | 02:36 AM
92redgsr's Avatar
Default Re: (TheGSRGuy)
Im on 5000 miles with a new rebuild and 280 across all four!
Old Mar 10, 2004 | 06:55 AM
Jon D's Avatar
Default Re: compression test? (Bbasso)
Me too B.....238 across all four!!!
Oh but dood those #'s fine, as stated your consistency doesnt alter which is a good sign.
Old Mar 10, 2004 | 01:22 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by top fuel &raquo;</TD></TR><TR><TD CLASS="quote">well i visited california this weekend and had to fly back but there is a deposit on the car and the seller went to go get it inspected for me and he told me that everything was fine, but the horn was disconnected because of the jdm conversion? (thats what he was saying) if this IS true could i able to connect it back?
edit: i also will be receiving the fax tomrrow</TD></TR></TABLE>
hmm.. do the test yourself.. i know its much trouble just to get someone to do it for you while you don't hvae the car yet.. i don't want you to loose an oportuninty to buy one..
Old Mar 10, 2004 | 02:28 PM
top fuel's Avatar
i got the fax from Acura of Santa Monica and nothing looks chopped or whatever
but i was wrong about 220 across the board he said 220 and i assumed all of em were 220 but actually the paper says
#1 = 220
#2 = 225
#3 = 220
#4 = 220
still good or what...
heres somes pics of the car also
Old Mar 10, 2004 | 03:04 PM
Numbers are fine...that variance isn't even worth worrying about.
Old Mar 10, 2004 | 04:24 PM
esponet's Avatar
looks like someone got lazy and looked up the specs and checked one cyl. and made up the rest.
damm dealer mechanics,
Old Mar 10, 2004 | 05:09 PM
TurblowR's Avatar
Default Re: (esponet)
sorry not to thread jack, but i have: 220,215,210,220. is this okay? i have about 40k miles on the car. test done with shitty kragen brand compression gauge.
Old Nov 26, 2004 | 01:37 PM
baonest's Avatar
Default Re: (TurblowR)
like people have been saying. as long as the #'s are +/- 20 psi. then its good.
i just did my '98 with 120K miles. ~250 across the board. but the compression tester wasnt at 0 (at like 20psi or so, even when i purged it.) which is odd because when i was reaching for it, it dropped on the garage floor, not hard, but hopefully the #s are still what they say.
Old Nov 28, 2004 | 12:45 AM
-=Zeqs=-'s Avatar
Default Re: (baonest)
I have about 245 all the way across, but I have a JDM ITR engine, which has higher compression from the factory.
220 with a 225 is nothing to worry about though. If one of the cylinders was 50 under, then worry.
joey1320
Honda S2000
Feb 19, 2008 05:33 PM
xd69
Mar 7, 2006 12:10 PM
ChronicGreenDC2
Jun 24, 2005 09:30 AM
snowblind7x
Apr 13, 2005 08:12 PM
projektCRX
Apr 22, 2004 12:18 PM
