passenger side axle problem
my passenger side axle is really wierd. i checked it out for the first time today and i noticed it was bent. its not straight. it is bending back. the tires not rubing or anything. but it looks wierd. what can i do to fix this? is this my subframe or just my axle?
Did you hit any curbs or anything like that? When I first got my ITR, I hit a curb and bent back my axle, upper and lower control arms. It sucked pretty bad.(finacially) Anyway, is the boot torn?
the car was in an accident...im not sure if boot is torn, but whenever i make a right turn, i hear a grinding noise..what is dat? and how much would it b to replace all that on the axle
1.You can get an axle for about $65 from Napa Autoparts.
2. when my upper control arm bent, I just replaced it with the skunk2 camber kit.
3. I forgot how much a lower control arm cost.
If it is just the axle, it will take about an hour to replace it.
If you hear a grinding/clicking noise, it's most probably your axle. Stupid question, but are you sure you're not talking about your tie rod being bent? Those usually bend before an axle (an axle will actually break before bending that much).
Any small car parts store will have Civic/Integra OEM replacement axles for pretty cheap. Even cheaper if you return the axle to them for the core exchange.
If you are mechanically inclined at all, it should take about 1 hour maximum to change the axle (provided you don't run into any problems such as tight/rusted bolts, etc). If it's your first time, it'll take a little longer maybe.
can u give me directions on how to change my axle or to change whatever you think is wrong wit the axle? i really dont know what to do when it comes to mechanical problems. thank you!
Can somene explain how the hell you bend an axle before bending the suspension???
As far as insall info, I'm sure there are more than enough threads on it, just search.
here ya go
https://honda-tech.com/zerothread?id=791611
^my sunday project....good luck on yours...doesnt sound too hard
Peteypablo17
Transmission & Drivetrain
Feb 10, 2013 05:31 PM
Corksil
Nov 23, 2009 01:30 PM
bennyp
Aug 24, 2008 09:31 PM
