obd-II
you can buy a clip that converts a obdII car to use a OBDI ecu hondata sells the clip and then you could use a 94 kord ecu i think...i believe you can buy the clip and a programable ecu from them and do it that way too.
[Modified by Sabastian, 7:58 AM 10/17/2001]
Ive never heard of those OBD2 to OBD1 adapters for accords, i know Skunk2 makes them for Civics and Tegs, as much as it is a headache why dont you do an OBD1 conversion? I think its the best solution.
You shouldnt look at it as getting alot more HP out of I/H/E with an OBD1 vs. OBD2 u should look at it from the perspective that your car will be alot more easier to tune and extract HP out of and will be less of a pain in the *** to make go fast
